Activity Forums Apple Final Cut Pro Legacy Importing JPEG Stills for Time-Lapse Sequence
  • Importing JPEG Stills for Time-Lapse Sequence
    Posted by Joe Taylor on April 17, 2011 at 9:53 pm
    I have some jpeg stills shot as a time-lapse sequence that are number as: IMG_4020 through IMG_4754. Problem is is when I import them into Final Cut Pro every frame is thrown completely out of sequence. This is the first time this has happened and I’m stumped. I’d think this would be an easy fix but alas…. can anybody help?
    Mark Suszko replied 15 years, 4 months ago 4 Members · 3 Replies
  • Zane Barker
    April 17, 2011 at 10:06 pm
    Use quick time & Pro to make a video from the images. Then bring that into FCP for your editing pleasure.
    https://www.flickr.com/photos/gothcandy/2504041553/
    **Hindsight is always 1080p**
  • Michael Gissing
    April 18, 2011 at 3:43 am
    If you sort by name in the bin, they should be in correct order
  • Mark Suszko
    April 18, 2011 at 2:24 pm
    The numbering of the images has to have one common name, then the computer sorts by number, and it can be thrown off id the number part odf each name doesn’t have the same number of digit places. If the last frame of a sequence has three digits, for example “testframe100.jpg”, the first frame has to be saved with zeros as placeholders so it reads as “testframe001.jpg.” Then the computer (any computer) will keep things properly organized.
    When I import jpeg or targa sequences, I create a separate bin for them, and pre-set the default duration for imported graphics to one frame. Grabbing a folder of the stills from whatever application exported them, I drag and drop this into the new bin and, assuming the naming convention I mentioned is correct, all is assembled correctly.
    From there I can do a “select all” and drag the entire sequence to the timeline. Generally, at thast pooint after I see how I like it, I’ll render out that part fo the timeline as a self-contained MOV file and import it back over the stills, so ti acts just like any other clip. It is not the only way to do this job, nor is it necessarily the best way; but it works for me.
