Activity Forums Apple Final Cut Pro Legacy Importing iTune files into FCP&
  • Importing iTune files into FCP&
    Posted by Frank Cervarich on November 12, 2009 at 5:01 pm
    Hi –
    I’ve got what I hope is a simple question for you experts. I have just upgraded to FCS3 from FCP4.5 when I purchased a new MacPro 8-core. One of the things I did was bring over all the music I had from my previous system into my new rig. Everything went great. Now I have pulled in some new music into iTunes and have attempted to import those files into FCP7. And I find that I am unable to choose those files even though I can choose the old files. Have I missed a setting in FCP? In iTunes? What am I doing wrong? Thanks for your help.
    Frank Cervarich replied 16 years, 9 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    November 12, 2009 at 5:15 pm
    Well, the format likely matters.
    FCP wants to see aif files, and not much else. MP3’s will import usually, but they aren’t supported for editorial in FCP.
    WHen you import new files you intend to edit with, then import them as Aiff files. This is set in the iTunes’ prefs.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Frank Cervarich
    November 12, 2009 at 5:38 pm
    Thanks Jerry,
    I will check that out. I know these files were MP3s so you have probably hit the nail on the head.
