Importing issues– Won’t import mpeg and avi footage only mp4 ?
Posted by Tristan Berry on April 12, 2012 at 3:18 amI don’t know much, but i know how to work vegas. Vegas will not import any Mpeg footage as well as avi’s. I have to convert them to Mp4 footage which hurts the quality. I would reinstall Vegas but i am scared that if i do so all my projects that i am currently working on will go to waste and i will not be able to get them back (which i will not risk.) Is there a fix for this?
Graham Bernard replied 14 years, 5 months ago 4 Members · 6 Replies -
Steve Rhoden
April 12, 2012 at 5:30 amHow will reinstalling Vegas makes all your projects go to waste?
From you have your vegas projects saved and tucked away in a folder,
you are quite okay to reinstall vegas anytime.Which version of Vegas do you have there? And was it importing those
file formats before?Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
1-876-832-4956 -
Tristan Berry
April 12, 2012 at 6:17 pmOkay, that is good to hear. I am using Vegas 11. I don’t think it was importing those files before, i just started using Vegas more frequently so tese issues have arised.
How would you suggest i go about reinstalling vegas? Delete it and remove it with Revo Uninstaller and then reinstall it? I’m not experienced etc. Thanks again!
Tristan Berry
April 12, 2012 at 10:08 pmI just reinstalled vegas… I now can import SOME Mpeg footage and some not. Vegas freezes when i try to import some of them and some it works. What is the problem…
Steve Rhoden
April 13, 2012 at 12:05 pmAhhh Tristan, Vegas 11 still has a few issues with it,
I am sad to say. But importantly, where did you get those
avi’s and Mpeg files?Steve Rhoden
(Cow Leader)
1-876-832-4956 -
Nigel O’neill
April 15, 2012 at 1:23 amTristan
Vegas will import AVI’s and MPEGs that conform to the industry standard. A lot of hardware manufacturers and software developers make their own proprietary (non-standard) video files which Vegas either does not recognise or does not handle well. Whilst you could install a CODEC pack which may allow you to import those files, they WILL destabilise Vegas.
I suggest you try and recapture the source using industry standard codecs. If this is coming from a cheap camera, you may have to edit your videos using the software that came with that camera.
My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
Graham Bernard
April 15, 2012 at 4:53 amTristan, like others here, I can import MPEG (MXF files) AVI, MP4. Mix then the Timeline and do everything you’d expect to do with them. As long as those same files abide by the industry standards. If I stray outside these standards then all bets are off!
Get GSpot or MediaInfo and establish just what you have. Could be that the CODECS for those files aren’t present on your PC. Now comes the really sticky icky point: DON’T install a CODEC pack, to attempt to read files that in themselves wouldn’t be seen by Vegas anyway. You could get into all types of issues.
Grazie
