Activity › Forums › Apple Motion › Importing into Motion…and rendering therein
  • Importing into Motion…and rendering therein
    Posted by John Mendelsohn on August 18, 2014 at 3:46 am
    Is there a way, when importing multiple JPEGs or PNGs, to avoid each of them going into a separate group?
    Also, why, when I’ve adjusted the In and Out bars on the Timeeline, does the program render even the stuff I wish to exclude? How to get it to render only between In and Out, please?
    Thanks very much in advance.
    John Mendelsohn replied 12 years, 1 month ago 2 Members · 2 Replies
  • Simon Ubsdell
    August 18, 2014 at 12:49 pm
    [John Mendelsohn] “Is there a way, when importing multiple JPEGs or PNGs, to avoid each of them going into a separate group?
    Shift select them in the Finder or File Browser and drag them into a group – rather than hitting the Import button.
    Also, why, when I’ve adjusted the In and Out bars on the Timeeline, does the program render even the stuff I wish to exclude? How to get it to render only between In and Out, please?”
    If you have a play range created (Alt/Cmd+I to set the inpoint, Alt/Cmd+O to set the outpoint), the Export movie dialogue will allow you to choose Use Play Range for the export duration. If you don’t have a play range set, this option will be greyed out.
    Simon Ubsdell
    tokyo-uk.com
  • John Mendelsohn
    August 18, 2014 at 4:46 pm
    Thanks, Simon.
