Activity › Forums › Apple Final Cut Pro › Importing incredibly slow and bypassing import errors.
Jeremy Garchow replied 13 years, 8 months ago 4 Members · 16 Replies
Jeremy Garchow
January 24, 2013 at 7:46 pm[Tangier Clarke] “Drive 2 Read Write = 118MB/s, 116.4MB/s
Drive 3 Read/Write = 134MB/s, 130MB/susing Blackmagics speed test
“Perfect, so it’s not your hard drives.
Jeremy Garchow
January 24, 2013 at 7:47 pm[Tangier Clarke] “It only keeps reindexing my boot drive.”
Do you have DropBox running?
Try turning it off for a while and see if that speeds anything up.
Also, when transcoding, are you still editing ro are you not touching FCPX?
Tangier Clarke
January 24, 2013 at 7:47 pmPerhaps a fresh install of Mountain Lion and FCP X is in order.
Tangier
Jeremy Garchow
January 24, 2013 at 7:50 pmMaybe.
I think at the very least, you should completely trash the index and start over.
Do this before you leave tonight and let it run over night.
If that doesn’t work, I reinstall of the OS might help. I don’t think any of this has to do with FCPX, but FCPX is hampered in performance due to this issue.
TUrning off spotlight via the Terminal will help you see if it’s the indexing of FCPX that’s not running correctly.
Tangier Clarke
January 24, 2013 at 7:58 pmYeah, I did all of that – using terminal, turning indexing off, trashing index file using Onyx app, restarting index yesterday, etc. I was surprised to see this indexing issue show up again on it’s own.
Thanks for your help though.
Tangier
Jeremy Garchow
January 24, 2013 at 8:02 pmIf you have done all the troubleshooting, then perhaps a Mountain Lion reinstall is needed.
Jeremy
