Activity › Forums › Adobe Premiere Pro › importing in premiere
Posted by Piff Aroni on May 14, 2013 at 4:08 pmI am a final cut user who has switched over to CS6. In FCP, we use to import in apple pro res they said it was the best quality.
I see the CS6 you can import and edit in the raw .mts files.
is this better then converting to another format?
Tim Kolb replied 13 years, 4 months ago 4 Members · 3 Replies -
Kris Merkel
May 14, 2013 at 4:31 pmThe beauty of PrPro is that you can read and work with native files without the need to transcode first. Depending on your workflow it is perfectly acceptable to work in the native format and let AME do the heavy lifting at the end of the cut. Some codecs will perform better than others and depending on your workstation specs your mileage may vary.
“Think of everything in terms of building capacity.”
Kris Merkel
twitter: @kris_merkel
Product Manager, Flanders Scientific Inc.
http://www.shopfsi.com
Co-Founder, Atlanta Cutters Post Production User Group
http://www.atlantacutters.com2.2Ghz MBP core i7
16Gb RAM
CS6/FCP7
AJA T-Tap
AJA IO XT
FSI LM-2461W/CM-170W -
Joe Barta iv
May 14, 2013 at 7:30 pmWe still convert our AVCHD files to ProRes, because it seems to play well with PP. I have no tech info but it feels like it is easier for PP to play more of the ProRes in real time than it is for it keep unpacking a highly compressed format.
Bars & Tone
SALUTE! -
Tim Kolb
May 15, 2013 at 1:04 amYou can certainly try the AVCHD files natively, but it does depend a bit on your hardware configuration.
If the native files don’t work easily, you can always use Prelude as your stand in “log and capture” to convert to ProRes if you like.
TimK,
Director, Consultant
Kolb Productions,Adobe Certified Instructor
