Activity › Forums › Apple Motion › Importing Images in Motion 5
Posted by Deva Sunya on September 3, 2012 at 1:25 amHi All…
I have a couple questions about importing images into Motion 5:
1- Is there any way to set the default length for an image when imported?
2- Is it possible to import a set of images so they are one after the other in the timeline instead of all layered on top of each other with their length the length of the project?
Peter Rudolfi replied 11 years, 11 months ago 4 Members · 6 Replies -
Aj Robinson
September 3, 2012 at 1:38 am -
Deva Sunya
September 3, 2012 at 2:20 amAhhh… thanks, that works for the image length. I saw layer length and did not think of it for images… much appreciated.
As for #2, FCP X you drag a group of images to the timeline and they are all in a linear sequence with each as long as the default setting. It is very easy.
Mark Spencer
September 3, 2012 at 4:58 amIf the images are numbered sequentially, i.e, pict0001, pict002, etc., then you tell Motion to view them all as a single movie file by clicking the Show Image Sequences as Collapsed button at the bottom of the File Browser. You can then import this file like any other movie and it will play one image per frame.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
https://www.applemotion.net -
Deva Sunya
September 3, 2012 at 5:19 amThanks for the reply…
There is not much control over the way they play… no transitions etc… I suppose if the images are actually the frames of a movie that makes sense… anyway, appreciate your reply…
Peter Rudolfi
October 20, 2014 at 11:06 pmAs far as “how the play” in n Image Sequence File, try in Properties/Timing/Frame Bending, changing that setting to Optical Flow. You’re in for some fun.
Mark Spencer has an excellent tutorial here on Morphing:
https://www.youtube.com/watch?v=4bQnr6kHwHY
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
