Activity Forums Adobe After Effects Importing Images from Online
  • Importing Images from Online
    Posted by Chaz King on January 9, 2019 at 5:39 pm
    I downloaded a template slideshow to use with pictures but I was curious if there was a way to import images from GooglePhotos/Folder on desktop similar to how After Effects can automatically update values in infographics using a JSON file. I feel like it would be much quicker to set up placeholders in the project and update a JSON file or something similar to update photos in it rather than having to go inside to the base layer of each comp to change each picture.
    Chaz King replied 7 years, 7 months ago 2 Members · 3 Replies
  • Walter Soyka
    January 9, 2019 at 6:41 pm
    My recommendation for this scenario involves a little bit of work upfront, but make updates super-fast later on.
    Create a PHOTOS comp. Import all your photos into this comp. Select all layers, set their duration to a single frame, then use the “Sequence Layers” keyframe assistant to make it a single sequence of images.
    In each of your placeholder precomps, place the PHOTO layer, enable time-remapping, and set it to a specific frame: 0 for the first image, 1 for the second image, 2 for the third image, and so-on.
    Once you’ve done that, if you want to update the photos, you just have to clear out the old photos, import the new ones, and re-sequence them.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Walter Soyka
    January 9, 2019 at 7:43 pm
    [Dave LaRonde] “I’ll guess that the photos should all have the same dimensions, too…”
    If the source photos do have different dimensions that should be retained, you can use Collapse Transformations on the PHOTOS comp layers without issue.
    Walter Soyka
  • Chaz King
    January 9, 2019 at 7:59 pm
    Thanks guys! I think creating the PHOTOS comp will be my best solution. And as far as them all being the same size I can adjust them perfume in the comp. The template is one that divides the screen so as long as I have it in the frame it will work
