Activity Forums Adobe Premiere Pro importing images and vector graphics
  • importing images and vector graphics
    Posted by Neil Bradley on May 21, 2007 at 5:23 am
    I was experimenting with importing high resolution photographs into a project created in Premier Pro with varying results and wondered what everyone else does?
    Id like to display photographs as part of a movie project and need the very best results as the images are an important part of the project. I import the images into Photoshop so can apply whatever setting to the file size or resolution. Then when I import the image into Premier Pro what fields setting give the best result?
    If I created typography in Photoshop and keep it as a vector graphic what resolution setting gives the best results? Also what field setting gives the type the best results when imported into Premier?
    Look forward to your advice…
    Vince Becquiot replied 19 years, 3 months ago 2 Members · 1 Reply
  • Vince Becquiot
    May 21, 2007 at 2:43 pm
    Neil,
    There are no fields in an imported image, since it is basically a full frame, the same you would find in progressive video. If the rest of your footage is interlaced, then the image will automatically be interlaced in the same order as the rest of the timeline on export.
    As for resolution, it is simple math. If you plan on zooming in at 200%, double the resolultion of the project you are working in.
    if you understand PAR, then you’ll probably take in account in Photoshop.
    Vince
