Activity Forums Adobe Photoshop importing images
  • importing images
    Posted by Hunter on February 7, 2006 at 10:49 pm
    Anyone tell me how to import a series of photos as a filmstrip. What I’m trying to do is import a video clip into photoshop in sequential order for rotoscoping. I know you could do it like this in photshop 3. The video was export form Avid in .PSD. Thanks so much
    Tim Kurkoski replied 20 years, 6 months ago 2 Members · 3 Replies
  • Tim Kurkoski
    February 7, 2006 at 11:55 pm
    Premiere and After Effects can export video clips as a Filmstrip (.FLM) file. It’s essentially a Photoshop file with the frames split up. Beware that these files get very large very quickly, and that will chew up Photshop’s memory. So if you have a long clip that you’re trying to edit, do the export as several shorter segments.
  • Hunter
    February 8, 2006 at 1:22 am
    Unfortunately I edit with Avid xpress pro HD and not Premiere and other way to import as filmstrip or arrange the psd documents within photoshop as a filmstrip?
    thanks
  • Tim Kurkoski
    February 8, 2006 at 6:37 am
    No. Only Premiere and AE can create FLM files that I know of. (It is a little curious that Photoshop can’t do it, but to construct the files manually would be a tremendous amount of work anyway.) You can always download the demo for AE and use that to make the FLM.
