Activity Forums Apple Final Cut Pro Legacy Importing image-sequences doesen’t work right
  • Importing image-sequences doesen’t work right
    Posted by Hinzkuntz on September 1, 2005 at 6:12 pm
    here’s the problem:
    when importing tga-files final cut always recognizes them with 25fps even when working in ntsc or 59,94 hd (1280×1024) hope somebody project.
    when dragging them into a timeline an error message appears
    “insufficient content for edit”.
    this only appears when setting the import option for still/freeze duration to one frame in the user preferences.
    when setting the duration to two frames final cut gives them a duration of one frame in the bin.
    but if i drag this images into a timeline the duration is not correct.
    example: a 30sek shot is now 60sek long and the play-back is half speed of the original.
    and it goes on: when dragging images into a 60p timeline every image has a duration of two frames.
    is it a bug in final cut 5?
    i think in final cut 4 the import worked without problems.
    hope somebody can help me.
    bye hinzkuntz
    Kai Whittaker replied 20 years, 11 months ago 3 Members · 2 Replies
  • Peter Wiggins
    September 1, 2005 at 6:46 pm
    You could always convert them in Quicktime Pro before importing the converted movie.
    Having a lot of still images really slows down FCP, especially opening & saving projects.
    Converting in Motion works well too.
    Peter
    https://www.peterwiggins.com
    Tinkering with Indigo (X10) at home before IBC
  • Kai Whittaker
    September 1, 2005 at 7:16 pm
    I agree.
    With Quicktime you choose exactly what the FPS rate is before you import the image sequence.
    Good luck!
