Activity Forums Adobe After Effects Importing image sequence
  • Importing image sequence
    Posted by Ron Craig on April 28, 2010 at 3:34 am
    For the life of me I can’t remember how I did this before and a search here didn’t turn up an answer. So I could use some help.
    I want to import a series of still images to After Effects as an image sequence and I would like each still to have a duration of two frames. I know how to set the default still image duration in preferences and that works fine to import a single still image at a specified duration. But when I import a series of stills as a sequence, the system reverts to a duration of one frame per still.
    I would really appreciate some advice on this. Thanks.
    — Ron
    Ron Craig replied 16 years, 2 months ago 2 Members · 2 Replies
  • Todd Kopriva
    April 28, 2010 at 9:29 am
    I think that you’re looking for this:
    “Change the frame rate of a sequence”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Ron Craig
    April 28, 2010 at 2:12 pm
    Thank you!!
    – Ron
