Activity Forums Adobe After Effects importing image sequence rendered using multimachine settings seems to flicker
  • importing image sequence rendered using multimachine settings seems to flicker
    Posted by Saudi on March 22, 2006 at 10:12 am
    Hi folks,
    when I import a image sequence, rendered using the standart multimachine settings, my result seems to flicker. I assume the problem is that my image sequence is rendered in 25p and the other footage is 50i. I tried to apply different interpretations (frame orders) for the imported sequence but it didnt work. Is it possible to render a image sequence in 50i or do I have to care about something else?
    Thanks for your help
    Martin
    Sebastien Allain replied 20 years, 5 months ago 2 Members · 1 Reply
  • Sebastien Allain
    March 22, 2006 at 1:18 pm
    Try to set “interpolation” off…
    If no result, let off and then choose upper field for each footage.
    sebastien
