Activity › Forums › Maxon Cinema 4D › importing illustrator question
Posted by Donavan Mcdougle on July 19, 2011 at 3:12 pmI’m importing an illustrator graphic (saving as Illustrator 8, it imports fine), but I’m trying to take that graphic and create a sphere – so the logo looks like it’s etched out of something like an egg shell. Basically trying to extrude and wrap. Extruding is no problem, but heck if I can figure out how to wrap this around a sphere (or turn it into a sphere). Can anyone give me some help?
Thanks!Charlie Davies replied 15 years, 2 months ago 4 Members · 7 Replies -
Greg Burrus
July 19, 2011 at 3:49 pmTry using the some of the deformers. I would suggest checking out either surface or wrap ones. Though others might work better depending on the look your going for.
hope this helps,
Greg
https://mogra.g2bproductions.com/ – Blog
https://g2bproductions.com/ – Portfolio -
Donavan Mcdougle
July 19, 2011 at 4:00 pmHi Greg, thanks for the reply! I’ve tried the deformers (Sphereify and Wrap) and I haven’t had any success. Neither creates a round sphere where I can extrude the cut out. Instead of round I get a chunky mess. I know I’m missing something but I’m not sure what… any other ideas would be gratefully appreciated!
Brian Jones
July 19, 2011 at 4:23 pmthe Caps of the Extrude can’t bend unless you set them to Quadrangles (or Tri) and check off Regular Grid then set the grid size small enough to be useful.
Donavan Mcdougle
July 19, 2011 at 4:36 pmThanks Brian, that’s good to know and I’m sure that would have been my next level of frustration. I’m still not getting my Illustrator image (it’s a single layer with a knock out of the logo) to either become a sphere or wrap around a sphere. This is the first time I’ve had to warp an Illustrator file and I’m sure I’m missing something…
Greg Burrus
July 19, 2011 at 5:39 pmHmm if it’s just a simple knockout and you don’t need to worry about the actual colors you could try using the bump or displacement channels via a texture. Then you could get an impression of the object. Bump might look really fake at close range so displacement might be better since it effects the geometry but it does slow things down.
Greg
Donavan Mcdougle
July 19, 2011 at 7:04 pmThanks Greg, that’s a completely different approach – I’ll give it a try!
Charlie Davies
July 20, 2011 at 2:42 pmAre the deformers not working becuase you don’t have any polygons on the surface of your imported spline?
