Activity Forums Adobe After Effects Importing Illustrator files into AE, specifically artboards
  • Importing Illustrator files into AE, specifically artboards
    Posted by Ryan Simmons on June 17, 2014 at 2:43 pm
    Hi all–
    I’m importing an Illustrator file into AE, and I’ve separated all the assets I want to manipulate into top-level layers in AI, but the AI project has multiple artboards. I’ve noticed that when I go to pull it into After Effects, it will only pull the layers that appear within the top artboard.
    If I change the order of the artboards, to try to bring more layers into AE, it will disconnect the layers that were on the previously top-most artboard.
    I’m thinking the solution is to save multiple copies of the AI project, each with a different artboard listed first. Then importing them into AE. Seems like a lot of work though. Is there another work around?
    Ryan Simmons replied 12 years, 2 months ago 2 Members · 2 Replies
  • Joseph W. bourke
    June 17, 2014 at 4:23 pm
    Here’s a very good explanation of importing Illustrator files to AE:
    https://www.jamesmerry.co.uk/home/?p=388
    If you just want to cut to the artboard issue, scroll down to Multiple Artboards.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Ryan Simmons
    June 17, 2014 at 6:02 pm
    Thanks Joe and Dave! Unfortunately I’m working with another designer’s work, which is, let’s just say, not up to my usual standards of organization. Thanks for the help!
