Activity Forums Maxon Cinema 4D importing illustrator files
  • importing illustrator files
    Posted by Robert on May 18, 2007 at 3:33 pm
    just a quick newbie question… my illustrator logo is coming in with multiple paths to Cinema. i’ve saved it as a compound path in AI and tried to group the paths, then extrude them but i’m not having any luck. Please help…
    Azdark Inutero replied 17 years, 4 months ago 8 Members · 10 Replies
  • 10 Replies
  • Govinda__
    May 18, 2007 at 3:58 pm
    Function>Connect
  • Alejandro Torres
    May 18, 2007 at 4:56 pm
    Or if you are using R10, select them and go to object>connect objects, then delete the old splines…
  • Robert
    May 18, 2007 at 5:28 pm
    i am using 10 and the connect does work thanks! is there a way to import AI files into an open project. whenever i try to open the file it opens a new project…
    r
  • Alejandro Torres
    May 19, 2007 at 2:53 pm
    There is a way but I can’t recall it right now. Just copy the spline from the new project into your existing one, that’s really all of it.
    Alejandro
  • Davesink
    May 21, 2007 at 8:10 pm
    To bring an AI file (or another C4D file) into an existing scene, use File/Merge.
    Also regarding your original question, an AI file (saved as version 8), with compound paths should extrude correctly without connectying all splines if you check the “Hierarchy” box in the extrude options window.
    Hope this helps.
    Dave W.
  • Aaron Aphasia
    June 5, 2007 at 7:29 pm
    File>Merge is the ticket! Oh and delete the old paths after you Connect them! A
  • Jorge Lega
    July 24, 2007 at 9:25 pm
    I’ve been trying to import an illustrator file to cinema 4D, and nothing seams to work. Ive going under file > merge > and then loading the ai file and nothing comes up. I’ve also tryed loading a eps file and that didn’t work either. Please if anybody can help…
    thanks
    Jorge E. Lega
    Design / Animation
    http://www.jorgelega.com
  • Mark Thomas
    March 26, 2009 at 7:00 pm
    Hi Jorge,
    Yes I’m having the same problem. Nothing happens, no object anywhere.
    Anyone?
    -Mark
  • Mark Thomas
    March 26, 2009 at 7:05 pm
    I figured it out. It must be saved as version 8.
    Yowza!
  • Azdark Inutero
    April 16, 2009 at 2:16 pm
    hello to all!!
    im trying to import a simple letter saved as a.i file from illustrator into 4dcimena to check out the program,but nothing is appearing when i clik open>import then i try open>merge incase it pops in the screen but nothing!!!
    anyone intereted in sharing his/her knowladge with me pls let me know!
    best regards!
