Importing Illustrator file to After Effects
So I was trying to make a reversed shatter text effects (following a video tutorial).
It told me to make text in Illustrator. Then turning on the outline so I could slice up the text into different layers. Then I saved it and imported it to After Effects. But to my suprise the file was cropped to 50×600-ish and was completely black. I could still select the layers and see that the selections boxes wwhere in place. I have tried saving the Illustrator file in CS4 (same as my After Effects) but that didn’t work. I haven’t come to think to anything else that could fix it. So I turn myself to you. 🙂Thanks in regards.
