Activity Forums Adobe After Effects Importing Illustrator CS4 files into AE
  • Importing Illustrator CS4 files into AE
    Posted by Daniel Dinardo on October 26, 2009 at 1:13 pm
    Has anybody had issues with elements created in Illustrator CS4 importing into AE the size of the artboard rather than the object size? Is there a setting in Illustrator that has changed from past version that I’m missing? Note that this only happens when I have one layer or when I import as merged footage.
    I can import as a composition with cropped layers fine. Elements created in Illlustrator CS3 come in cropped, but if I open them up in CS4 and do a straight save they import the size of the artboard. Also, I can save as a .eps in CS4 and objects import fine. Thanks in advance for any info.
    Terry Hahin replied 16 years, 11 months ago 2 Members · 1 Reply
  • Terry Hahin
    October 26, 2009 at 5:51 pm
    HI DANIEL,
    I just edit the artboards prior to importing the .AI into AE. Got to Document Setup, then edit artboards in Illustrator.
    Hope that helps
    Terry Hahin
    Designer and Editor
    terryhahin.com
