Activity Forums Adobe After Effects Importing Illustrator CS3 file as a Comp
  • Importing Illustrator CS3 file as a Comp
    Posted by Paul Meyer on July 22, 2007 at 5:17 pm
    I created an Illustrator CS3 file with an embedded picture. When I import the AI file into After Effect CS3 as a comp, AE will show all of the layers except for the one with the embedded picture. It identifies the layer, but the picture will not appear.
    Any suggestions would be greatly appreciated.
    -Paul
    Jeff Mcbride replied 19 years, 1 month ago 3 Members · 2 Replies
  • Steve Roberts
    July 23, 2007 at 1:22 pm
    Never heard of this — must have something to do with the picture being linked in AI, and not psted onto a layer, maybe. I really don’t know.
    If you can’t find a way to make the picture part of the AI file (again, I don’t know), you might have to make a rectangle in place of the photo in AI, import the file into AE, then import the photo separately into AE and align it to the rectangle.
  • Jeff Mcbride
    July 23, 2007 at 6:48 pm
    Does saving as an EPS file change anything? I’m assuming your eye is checked on for that layer in AE and Il
