Activity Forums Apple Final Cut Pro Legacy Importing HD animation into NTSC 10-bit uncompressed sequence
  • Importing HD animation into NTSC 10-bit uncompressed sequence
    Posted by Evan John on March 25, 2009 at 3:18 pm
    I am importing a 1920×1080 HD animation with an upper-field dominance into a NTSC uncompressed 10-bit sequence. What’s the easiest way to get rid of the interlacing that’s occuring. I tried changing the field dominance setting in the clip settings, but no dice.
    Rafael Amador replied 17 years, 6 months ago 2 Members · 1 Reply
  • Rafael Amador
    March 25, 2009 at 4:43 pm
    Hi Evan,
    If you can not get the animation exported Progressive from AE, the only solution is de~interlace.
    The only de~interlacer that works in 10b in FC is the Nattress.
    Cheers,
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
