Activity Forums Avid Media Composer importing from XDCam
  • importing from XDCam
    Posted by Lori Porter on December 20, 2009 at 8:30 pm
    Hi
    Anyone have any issues importing files from XDCam (off the disk into the Avid). I have Media Composer 3.5 – just upgraded this summer so that I could import from the XDCam… and now when I go to import what is on the disk – I get a command to reformat the disk. I KNOW the information is on the disk…
    Any help would be greatly appreciated!
    Lori
    Ed Cilley replied 16 years, 9 months ago 4 Members · 6 Replies
  • Gary Hazen
    December 21, 2009 at 12:11 am
    Did you install the PDW U-1 driver ?
    Is AMA off or on ?
  • Lori Porter
    December 21, 2009 at 2:49 am
    Hi Gary. Thanks for your help. I’m a freelancer and one of the guys I work for just dropped off the drive… so no, I did not install the driver. I can probably get it from him – or do you know if I can get it online for free from SONY.
    Also – don’t mean to sound like a dope – but what is AMA.. I don’t know if it’s on or off. I’ll go see right now if I can get the PDW-U1 driver…
    Thanks again.
    Lori
  • Gary Hazen
    December 21, 2009 at 2:07 pm
    Here’s the driver.
    https://servicesplus.us.sony.biz/sony-software-model-PDWU1.aspx
    But if you’re at a facility using their hardware then please ask for permission before installing software on their machines.
    AMA (Avid Media Acess) is a new way of getting at the media, I think it works similar to FCP in that you don’t need to import the media. I’m still running on 3.0 so I haven’t had a chance to mess around with it. From what I understand though, using AMA disables the XDCAM import functions of the import tool. Perhaps Job or someone else more familiar with AMA can explain more clearly.
  • Lori Porter
    December 21, 2009 at 5:35 pm
    Thanks Gary – Yes, I went to the SONY site last night and got the driver (thank you for posting it though) I work from home and have my own Avid – so no issues on putting it on anyone else’s machines. Once installed everything was fine.
    The AMA is on… not sure how to turn it off (didn’t mess with it last night) – but yes, it just instantly brings the media into the project… however – as soon as the device isn’t hooked up, the media is gone… I imported the media as well – the “old fashioned” way and all seems to be going great.
    One more question if you don’t mind. The footage was shot as 16:9. Should I just apply the 16:9 letterbox in the efx drop down under reformat or do I need to be using my editing windows in a 16:9 format? Not sure if I’m being clear… I know this all may seam like the dinasaur age for times now… but my “bosses” are just getting into it. Before I left my commercial job – we didn’t do much with 16:9…
    Thanks again for all your help. Take care and have a great holiday.
    Lori
  • Jandle Johnson
    December 21, 2009 at 7:49 pm
    Just turn on the 16 x 9 monitors in your settings. The reformat effect is for adding a letter box to anamorphic(squeezed)footage for 4×3 output.
    The AMA function is good for gaining immediate access to the XDCAM footage. I usually use it to choose my selects and then consolidate what I want onto my hard drive.
  • Ed Cilley
    December 22, 2009 at 1:51 am
    Lori,
    As far as the 16×9 question, Jandle was correct, just turn on 16×9. If you are monitoring on external monitors and can select 16×9, do this also.
    As an aside, by changing your edit window to 16×9 any text created in the Text Tool will be formatted properly. Otherwise your text will be formatted for 4×3 and when viewed on a monitor (in 16×9) your text will be stretched.
    Hope this adds a little more insight – and don’t worry about asking questions, that’s what we’re here for.
    Ed
    Avid and FCP Preditor
    _________________________________________________
    Anything worth doing at all, is worth doing well.
    – Philip Dormer Stanhope, Earl of Chesterfield
