Activity › Forums › Apple Final Cut Pro › Importing from Panasonic AG-HPX600
Posted by Lars Hogeus on April 13, 2017 at 9:04 amHi, I´m importing from the Panasonic AG-HPX600.
FCPX separates video and audio to separate files.
Is there a solution to avoid that?
Thanks, Lars
Doug Metzreplied 9 years, 5 months ago 3 Members · 12 Replies
Noah Kadner
April 13, 2017 at 1:44 pmDescribe your ingest workflow starting from attaching the card to your Mac.
Noah
FCPWORKS – FCPX Workflow
FCP Exchange – FCPX Workshops
XinTwo – FCPX Training -
Lars Hogeus
April 13, 2017 at 3:09 pmHi,
I put the P2 card in a reader, then drag and drop the complete folder in finder, to my Promise Pegasus drive.
In FCPX I press command I, and import all.
I have also tried to drag and drop the folder from finder to FCPX.
In both cases FCPX creates Keyword collections för VIDEO, AUDIO and ICONS.
The video files is only video, and audio files is only audio.
Lars
Noah Kadner
April 13, 2017 at 6:23 pmTry mounting the card and selecting as media in the import window not just dumping all files into an event
https://support.apple.com/kb/PH12749?locale=en_US&viewlocale=en_US
Noah
Lars Hogeus
April 13, 2017 at 9:23 pmIsn´t that what I´m doing when using command I?
As I described before, I´ve tried both drag and drop, and the import window.
/Lars
Noah Kadner
April 14, 2017 at 1:42 amBut are you selecting file names or actually seeing full clips with frames in the Import window? It sounds like you’re dragging in the entirety of the card which is why you’re getting separate pieces of media.
That said I’ve heard of this issue before I believe you need a driver from Panasonic to resolve it:
https://eww.pass.panasonic.co.jp/pro-av/support/content/download/EN/ep2main/macp2driver_e.htm
Noah
Lars Hogeus
April 14, 2017 at 4:55 amA strange thing is that can only see files, not folders, in the import window.
That´s for everything, example Canon C300 and Sony F5.
I will try the driver later.
Thanks, Lars
Doug Metz
April 18, 2017 at 2:16 pm[Lars Hogeus] “The driver did not help me…”
What version of MacOS / FCPX are you running?
Doug Metz
Anode
Doug Metz
April 19, 2017 at 2:47 pmCould you post a screen shot of the Import window?
Doug Metz
Anode
