Importing from P2 Card
Posted by Dave Simpson on August 22, 2012 at 8:50 pmHi All,
I’m trying to import footage from a Panasonic P2 Card and card reader. When I go to “Import Panasonic P2” I can view the thumbnails and select the clips I want no problem. When I click import it starts the process then crashes Media 100. I’m using version 2.0.1 and am working in DVCPRO HD.
I did try several different clips with the same result.For today I went into Final Cut and did the log and transfer then just imported into a Media 100 bin which works fine. I’m just curious if anyone else works with P2 cards & Media 100 and can offer any insight as to what may be the problem.
It’s always more fun to just work right in Media 100 and avoid Final Cut 😉
Thank You
Dave Simpson
Dave Simpson replied 14 years, 1 month ago 3 Members · 4 Replies -
Fermin Branger
August 24, 2012 at 12:42 amDo you have both applications installed on the same computer?
Fermin Branger
ALFARERIA CINEMATOGRAFICA
Caracas, Venezuela.
http://www.alfareriacine.com -
Floh Peters
August 24, 2012 at 9:06 amHmmm, usually this should work. Can you give more information about this crash? Does it crash when starting the import, or after the clip is finished? What do you get in the crash information window? It could be related to a “bad” 3rd party QuickTime component, or to a drive problem, or…
Dave Simpson
August 24, 2012 at 2:45 pmHello Fermin,
Thanks for the reply. Yes, both application are installed on the same machine.
Dave
Dave Simpson
August 24, 2012 at 2:54 pmHello Floh,
Thanks for the reply. The import progress bar will come up, then the crash usually occurs either within seconds or about half way to two thirds of the way through. It varies though.
When I import the footage from the Final Cut folder into Media 100 it looks great and behaves as expected.I’m not at all good at deciphering these, but here is the crash report:
Process: Media 100 Suite [10542]
Path: /Applications/Media 100 Folder/Media 100 Suite.app/Contents/MacOS/Media 100 Suite
Identifier: com.Media100.Media100Suite
Version: 2.0.1 (2.0.1)
Code Type: X86 (Native)
Parent Process: launchd [178]Date/Time: 2012-08-24 10:43:23.788 -0400
OS Version: Mac OS X 10.6.7 (10J869)
Report Version: 6Interval Since Last Report: 422241 sec
Crashes Since Last Report: 9
Per-App Interval Since Last Report: 6248 sec
Per-App Crashes Since Last Report: 6
Anonymous UUID: 217E1823-9531-4ACA-9822-BC5B7ADBD39AException Type: EXC_ARITHMETIC (SIGFPE)
Exception Codes: EXC_I386_DIV (divide by zero)
Crashed Thread: 0 Dispatch queue: com.apple.main-threadThread 0 Crashed: Dispatch queue: com.apple.main-thread
0 com.Media100.Media100Suite 0x00178c4d PopulateMovieResourceForVideo(ImageDescription**, short, FSSpec const&, CVideoInfo const&, MovieType**, unsigned char, char**, char**) + 223
1 com.Media100.Media100Suite 0x0017917d MakeQuickTimeFromM100Clip(ImageDescription**, FSSpec const*, unsigned char, unsigned char, short) + 1087
2 com.Media100.Media100Suite 0x0017a23d VerifyMediaIsVideo(MediaType**, ImageDescription**, TFile&, char***, char***, unsigned long&, EAspectRatioImportType, M100ReferenceMovieDataVector*) + 3735
3 com.Media100.Media100Suite 0x0017b3b0 IsMovieM100Clip(FSSpec const&, bool, EAspectRatioImportType, bool&, bool&, bool&, TimeCode&, String&, M100ReferenceMovieDataVector*, ImageDescription***) + 1176
4 com.Media100.Media100Suite 0x0017b8df IsFileM100Clip(FSSpec const&, bool, EAspectRatioImportType, bool&, bool&, bool&, TimeCode&, String&, M100ReferenceMovieDataVector*, ImageDescription***) + 91
5 com.Media100.Media100Suite 0x0024a5a0 HandleImportFile(TFile*) + 1288
6 com.Media100.Media100Suite 0x0024be42 HandleImportFiles(CList_AC*) + 75
7 com.Media100.Media100Suite 0x0030e119 TImportHelper::Done() + 1717
8 com.Media100.Media100Suite 0x004b920b TP2ImportCommand::DoIt() + 1017
9 com.Media100.Media100Suite 0x00514bea TCommand::PerformSimpleCommand(TCommand*) + 34
10 com.Media100.Media100Suite 0x00514f4b TCommand::PerformCommand(TCommand*) + 175
11 com.Media100.Media100Suite 0x004b48c8 TImportP2DialogView::DoImport() + 398
12 com.Media100.Media100Suite 0x000590b9 Dan::DoMenuCommand(long) + 3533
13 com.Media100.Media100Suite 0x00311566 TScriptMenuBehavior::DoMenuCommand(long) + 768
14 com.Media100.Media100Suite 0x00462665 TUndoHistoryBehavior::DoMenuCommand(long) + 303
15 com.Media100.Media100Suite 0x00081c61 BinDocument::DoMenuCommand(long) + 2479
16 com.Media100.Media100Suite 0x005892ff TUndoHandler::DoMenuCommand(long) + 243
17 com.Media100.Media100Suite 0x00094dc7 BinView::DoMenuCommand(long) + 1415
18 com.Media100.Media100Suite 0x0055dbdd TDispatcher::MenuEvent(short, short) + 123
19 com.Media100.Media100Suite 0x0055e6c2 TDispatcher::HandleMouseDown(TToolboxEvent*) + 306
20 com.Media100.Media100Suite 0x00052a4b Dan::HandleMouseDown(TToolboxEvent*) + 63
21 com.Media100.Media100Suite 0x0055e216 TDispatcher::HandleToolboxEvent(TToolboxEvent*) + 66
22 com.Media100.Media100Suite 0x0005169b Dan::PollToolboxEvent(bool) + 229
23 com.Media100.Media100Suite 0x0055d8dc TDispatcher::PollEvent(bool) + 82
24 com.Media100.Media100Suite 0x0055b33d TDispatcher::MainEventLoop() + 41
25 com.Media100.Media100Suite 0x0055d658 TDispatcher::Run() + 286
26 com.Media100.Media100Suite 0x0004a2c9 RunTheApplication(Dan*) + 147
27 com.Media100.Media100Suite 0x0004b525 main + 497
28 com.Media100.Media100Suite 0x00045e92 start + 54Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x94fa2922 kevent + 10
1 libSystem.B.dylib 0x94fa303c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x94fa24f9 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x94fa229e _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x94fa1d21 _pthread_wqthread + 390
5 libSystem.B.dylib 0x94fa1b66 start_wqthread + 30Thread 2:
0 libSystem.B.dylib 0x94f7c09a mach_msg_trap + 10
1 libSystem.B.dylib 0x94f7c807 mach_msg + 68
2 com.apple.CoreFoundation 0x9650337f __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x96502464 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x965083a4 CFRunLoopRun + 84
5 com.apple.DVCPROHDMuxer 0x1e08a98f AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 317
6 libSystem.B.dylib 0x94fa97fd _pthread_start + 345
7 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 3: Copy_Thread_Farm
0 libSystem.B.dylib 0x94f7c0d6 semaphore_wait_trap + 10
1 …Media100.Embedded.framework 0x1ad31b4b Thread_Farm::Thread_Farm_Main(Thread_Farm_Task_Info*) + 87
2 …Media100.Embedded.framework 0x1ad31a40 Thread_Farm::Work_Thread_Runner(void*) + 24
3 …ple.CoreServices.CarbonCore 0x92d6b7ca PrivateMPEntryPoint + 68
4 libSystem.B.dylib 0x94fa97fd _pthread_start + 345
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 4: Copy_Thread_Farm
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 5: Copy_Thread_Farm
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 6: Copy_Thread_Farm
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 7: Convert_Thread_Farm
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 8: Convert_Thread_Farm
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 9: Convert_Thread_Farm
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 10: Convert_Thread_Farm
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 11: PM_ManagerListener Socket – (MGR0)
1 …Media100.Embedded.framework 0x1ad33037 Thread_Engine::Thread_Main() + 161
2 …ple.CoreServices.CarbonCore 0x92d6b7ca PrivateMPEntryPoint + 68
3 libSystem.B.dylib 0x94fa97fd _pthread_start + 345
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 12: PM_ForegroundReceiveProc
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 13: RTE_Socket – (RTE )
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 14: Host_Foreground_Socket – (MacF)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 15: Host_Kernel_Socket – (MacK)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 16: Disk_Engine_Socket – (Disk)
0 libSystem.B.dylib 0x94f7c0ee semaphore_timedwait_trap + 10
1 …Media100.Embedded.framework 0x1adb8c5b BE_Semaphore::Wait(unsigned long) + 97
2 …Media100.Embedded.framework 0x1ad33037 Thread_Engine::Thread_Main() + 161
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 17: Disk Engine Farm
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 18: Disk Engine Farm
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 19: Disk Engine Farm
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 20: Disk Engine Farm
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 21: RTE_Socket – (RTEI)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 22: Application_Socket – (APPi)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 23: Subsampler Process_Runner
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 24: Player Video Effects
1 …Media100.Embedded.framework 0x1ad33f40 Thread_Work_Group::Work_Thread_Main(Work_Group_Task_Info*) + 328
2 …Media100.Embedded.framework 0x1ad33c1e Thread_Work_Group::Work_Thread_Runner(void*) + 24
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 25: Player Video Effects
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 26: Player Video Effects
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 27: Miff_Reader_Socket – (MIFF)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 28: App Socket – (Hart)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 29: App Socket – (subS)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 30: App Socket – (subR)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 31: App Socket – (ApTp)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 32:
5 …dia_100. Media_100_Firewire 0x1869085e AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 135
7 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 33: com.apple.CFSocket.private
0 libSystem.B.dylib 0x94f9b066 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x96542c83 __CFSocketManager + 1091
2 libSystem.B.dylib 0x94fa97fd _pthread_start + 345
3 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 34: App Socket – (Snfp)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 35: Player RTE_Deck_Socket – (RTED)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 36: Player RTE_Deck_Socket – (RTED)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 37: Player RTE_Deck_RT_Socket – (RTRT)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 38: MFOD_Cache_Socket – (MFOD)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 39: Player Codec
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 40: Player Codec
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 41: Player Codec
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 42: Player Codec
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 43: Red Decoder
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 44: Player Audio Processing
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 45: Player Audio Processing
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 46: Player Audio Processing
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 47: App Socket – (Daup)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 48: Player_Engine
1 …Media100.Embedded.framework 0x1ad42010 Board_Engine::Wait_For_Action() + 30
2 …Media100.Embedded.framework 0x1ad42f72 Board_Engine::Work_Thread() + 316
3 …Media100.Embedded.framework 0x1ad42514 Board_Engine::Work_Thread_Runner(void*) + 32
4 …ple.CoreServices.CarbonCore 0x92d6b7ca PrivateMPEntryPoint + 68
5 libSystem.B.dylib 0x94fa97fd _pthread_start + 345
6 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 49:
0 libSystem.B.dylib 0x94f7c0fa semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x94fa9c85 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x94fd8aa8 pthread_cond_timedwait_relative_np + 47
3 com.apple.audio.CoreAudio 0x958383c7 CAGuard::WaitFor(unsigned long long) + 219
4 com.apple.audio.CoreAudio 0x9583b3f9 CAGuard::WaitUntil(unsigned long long) + 289
5 com.apple.audio.CoreAudio 0x95838cf6 HP_IOThread::WorkLoop() + 1892
6 com.apple.audio.CoreAudio 0x9583858d HP_IOThread::ThreadEntry(HP_IOThread*) + 17
7 com.apple.audio.CoreAudio 0x958384a4 CAPThread::Entry(CAPThread*) + 140
8 libSystem.B.dylib 0x94fa97fd _pthread_start + 345
9 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 50: Player RTE_Deck_Socket – (RTED)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 51: Player RTE_Deck_Socket – (RTED)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 52: Player RTE_Deck_RT_Socket – (RTRT)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 53: MFOD_Cache_Socket – (MFOD)
4 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 54: Player Codec
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 55: Red Decoder
5 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 56:
3 …ple.CoreServices.CarbonCore 0x92d8be3d TSWaitOnConditionTimedRelative + 242
4 …ple.CoreServices.CarbonCore 0x92d8bb7b TSWaitOnSemaphoreCommon + 511
5 …ickTimeComponents.component 0x9803f591 ReadSchedulerThreadEntryPoint + 4698
7 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 57:
5 …ple.CoreServices.CarbonCore 0x92de66ee AIOFileThread(void*) + 1127
7 libSystem.B.dylib 0x94fa9682 thread_start + 34Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000258 ebx: 0x00000000 ecx: 0x00000000 edx: 0x00000000
edi: 0x02aed67c esi: 0x03b76c10 ebp: 0xbfffc498 esp: 0xbfffc440
ss: 0x0000001f efl: 0x00210246 eip: 0x00178c4d cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x000e3000Binary Images:
0x1000 – 0xc3ffeb +com.Media100.Media100Suite 2.0.1 (2.0.1) <74702247-8376-C68B-8C57-9A5D8522BCDC> /Applications/Media 100 Folder/Media 100 Suite.app/Contents/MacOS/Media 100 Suite
0x1787000 – 0x178bff7 com.apple.iokit.IOQTComponents 1.6 (1.6) /System/Library/Components/IOQTComponents.component/Contents/MacOS/IOQTComponents
0x17fa000 – 0x17faff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
0x3718000 – 0x372bfef com.apple.FCP Uncompressed 422.component 2.0 (546.9) /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
0x3730000 – 0x373dffb +net.telestream.license 1.0.9.3-GC (1.0.9.3-GC) <77301FCB-B789-671B-9FEC-9852A1240F83> /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
0x3753000 – 0x3768fcb +com.3ivx.videocodec 503.49 (503.49) /Library/QuickTime/3ivxVideoCodec.component/Contents/MacOS/3ivxVideoCodec
0x37ae000 – 0x37b0ff3 com.apple.LiveType.component 2.1.4 (2.1.4) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x37b6000 – 0x37b9ff3 +com.divx.divxtoolkit 1.0 (1.0) /Library/Frameworks/DivX Toolkit.framework/Versions/A/DivX Toolkit
0x37be000 – 0x37c0ff7 Motion 729.0.0 (compatibility 1.0.0) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
0x37c6000 – 0x37d7fff +com.media100.i.QuickTimeCodec.component 2.0.1 (2.0.1) <7C92FFCF-49C7-D18D-773C-C1BA0F966677> /Library/QuickTime/Media100.component/Contents/MacOS/Media100
0x37f8000 – 0x37faff7 libclparser.dylib ??? (???) /System/Library/Frameworks/OpenCL.framework/Libraries/libclparser.dylib
0x17657000 – 0x176bbfe2 com.apple.LiveType.framework 2.1.4 (2.1.4) /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
0x176db000 – 0x17733fff +com.DivXInc.DivXDecoder 6.8.4.3 (6.8.4) <26A406B3-E4BC-C6FF-8F28-A99FFEB5CF2D> /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
0x17757000 – 0x1779dffb com.apple.motion.component 1.0 (729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x177a3000 – 0x17840ff8 com.apple.procore.framework 4.0.2 (757) /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
0x17880000 – 0x17b15ffb +org.perian.Perian 1.2.1 (1.2.1) <7FBFA9CD-68D1-DFB5-6296-A11B06B62B37> /Users/admin/Library/QuickTime/Perian.component/Contents/MacOS/Perian
0x17f60000 – 0x18030ffb +lib3ivxEnc.dylib ??? (???) /Library/Application Support/3ivx/lib3ivxEnc.dylib
0x181e9000 – 0x181edff7 libcldcpuengine.dylib 1.5.6 (compatibility 1.0.0) /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
0x18401000 – 0x1840dfff com.apple.FinalCutPro.iChatTheaterPreview 1.0 (195) /Library/QuickTime/iChatTheaterPreview.component/Contents/MacOS/iChatTheaterPreview
0x18680000 – 0x186b0fff com.Media_100. Media_100_Firewire 1.0 (42) <93498F25-B85B-5D54-5917-94CBA334F3FD> /System/Library/Frameworks/Media_100_Firewire.framework/Versions/A/Media_100_Firewire
0x186e1000 – 0x18705fe7 GLRendererFloat ??? (???) <0C6A1BCF-97F0-F7D6-C840-2991681BB67C> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x18718000 – 0x1871cff3 com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <474B24B9-8CAE-D35D-7A5A-D07CFF58F349> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x18721000 – 0x18727ffb com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <41652FA7-74E5-B934-3E04-B3F89D80ABF3> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x1872c000 – 0x18781fe2 com.apple.DVCPROHDAudio 1.3.2 (1.3.2) /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
0x187d3000 – 0x187d4ff7 ATSHI.dylib ??? (???) <56F243F1-C341-86EA-2BCC-31E75D46EBBC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x18b3d000 – 0x18c85ff3 +com.media100.HD.QuickTimeCodec.component 2.0.1 (2.0.1) <0AB69E12-B7C2-9F7D-3897-C49D6DEDDC70> /Library/QuickTime/Media100 HD.component/Contents/MacOS/Media100 HD
0x18ccf000 – 0x18ec4fe2 +net.telestream.wmv.import 2.4.4.2 (2.4.4.2) /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
0x18ef9000 – 0x18faefe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) /usr/lib/libcrypto.0.9.7.dylib
0x19f4b000 – 0x19f62fff +com.eSellerate.EWSMac67108872 4.0.0.8 (4.0.0.8) <0E4BA0E6-33F5-4CA3-5DB1-7AC20BAA8F9B> /Library/Frameworks/EWSMac-GC.framework/EWSMac-GC67108872
0x19f6f000 – 0x19f75fff +com.matrox.vpg.mvMPEG2IFrameComponent MPEG2IFrameComponent version 1.0.2 (1.0.0) <1834A557-ABE6-231B-1FD5-CA351D9B0905> /Library/QuickTime/com.matrox.vpg.MPEG2IFrame.component/Contents/MacOS/com.matrox.vpg.MPEG2IFrame
0x19f80000 – 0x19fd0ff3 libMatroxMpeg2IFrameCodec.dylib ??? (???) <2949680B-8898-27C6-EDF0-F7B120D71A49> /usr/lib/libMatroxMpeg2IFrameCodec.dylib
0x1a42c000 – 0x1a5eefe2 +net.telestream.wmv.advanced 2.4.4.2 (2.4.4.2) <611D64FD-48DB-356C-D3FB-D96F131B00F5> /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
0x1a632000 – 0x1a65afe3 com.apple.AppleAVCIntraCodec 2.0 (542.4) /Library/QuickTime/AppleAVCIntraCodec.component/Contents/MacOS/AppleAVCIntraCodec
0x1a664000 – 0x1a6ebff7 com.apple.AppleProResCodec 3.0.1 (553.2) <6E207B31-DE83-BF92-990F-24328404C5AF> /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/AppleProResCodec
0x1a729000 – 0x1a7a3fef com.apple.AppleVAH264HW.component 2.0 (1.0) <6DA1BA82-A66D-6098-7989-965ADF1E9C7C> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
0x1a866000 – 0x1a8a2fe3 com.apple.QuickTimeFireWireDV.component 7.6.6 (1756.15) <9C48FD18-B6B8-10FA-3B09-47915626A73C> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x1a8ae000 – 0x1a8bbfff +com.panasonic.DVCProHDCodec 1.0 (1.0) /Library/QuickTime/PanasonicDVCProHDCodec.component/Contents/MacOS/PanasonicDVCProHDCodec
0x1a8c4000 – 0x1a901fe7 com.apple.DVCPROHDCodec 2.0 (542.4) /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
0x1a911000 – 0x1a9c5fef com.apple.AppleHDVCodec 2.0.1 (553.8) <5F48585B-5E48-549D-1E1B-F1BF68F8B753> /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
0x1a9e1000 – 0x1aa03ff7 com.apple.AppleIntermediateCodec 2.0 (542.4) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0x1aa12000 – 0x1aa28ffb com.apple.IMXCodec 2.0 (547.2) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
0x1aa3a000 – 0x1aa53fe7 com.apple.applepixletvideo 1.2.19 (1.2d19) <4A68731C-8071-6CF5-012C-40F00CD1333A> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x1aa58000 – 0x1acc5ff3 +com.canon.XFUtility.XFMpeg2DecComponent 1.0.1.16 (1.0.1.16) /Library/QuickTime/XFMpeg2Dec.component/Contents/MacOS/XFMpeg2Dec
0x1acf3000 – 0x1b111fef com.Media100.Embedded.framework 1.0 (1.0) /System/Library/Frameworks/Media_100_Embedded.framework/Media_100_Embedded
0x1de15000 – 0x1e050fff com.apple.ATIRadeonX1000GLDriver 1.6.26 (6.2.6) /System/Library/Extensions/ATIRadeonX1000GLDriver.bundle/Contents/MacOS/ATIRadeonX1000GLDriver
0x1e073000 – 0x1e0d8fe0 com.apple.DVCPROHDMuxer 1.3.2 (1.3.2) /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
0x5facf000 – 0x5fc47fe7 GLEngine ??? (???) <0E1DF3E4-0EEE-9FD8-8F52-FFFCF0DF23A7> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x5fe65000 – 0x5fe65ff7 com.apple.applescript.component 2.1.2 (2.1.2) /System/Library/Components/AppleScript.component/Contents/MacOS/AppleScript
0x5fe69000 – 0x5fe6bff7 com.apple.PDFImporter 2.1 (???) /System/Library/Components/PDFImporter.component/Contents/MacOS/PDFImporter
0x5fe71000 – 0x5fe73ff3 +jp.co.panasonic.MXFImporter 1.2.1 (1.2.1) /Library/QuickTime/MXFImporter.component/Contents/MacOS/MXFImporter
0x60cd9000 – 0x60d5dfe7 com.apple.xquery 1.3 (29) <983B85B3-9590-F3B4-C3B0-C73ADBC92C3F> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
0x6dfc6000 – 0x6e083fe2 com.apple.DesktopVideoOut 1.2.7 (1.2.7) <54E0C747-1169-FB4A-2CB4-9EA9BD5398F8> /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
0x6e416000 – 0x6e4aefff com.apple.applescript 2.1.2 (2.1.2) /System/Library/PrivateFrameworks/AppleScript.framework/Versions/A/AppleScript
0x6e51d000 – 0x6e601fe7 com.apple.QuickTime3GPP.component 7.6.6 (1756.15) <52F0B493-9FBE-FD4F-F8BC-5DB08D01E8EC> /System/Library/QuickTime/QuickTime3GPP.component/Contents/MacOS/QuickTime3GPP
0x6e628000 – 0x6ea06fe2 +net.telestream.wmv.export 2.4.4.2 (2.4.4.2) /Library/QuickTime/Flip4Mac WMV Export.component/Contents/MacOS/Flip4Mac WMV Export
0x6eaed000 – 0x6eb2efe3 com.apple.audio.SoundManager.Components 3.9.4 (3.9.4) /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x6eb35000 – 0x6ed1bfef com.apple.audio.codecs.Components 2.0.3 (2.0.3) /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x6ee7d000 – 0x6ef1fff3 com.apple.QuickTimeVR.component 7.6.6 (1756.15) /System/Library/QuickTime/QuickTimeVR.component/Contents/MacOS/QuickTimeVR
0x6ef46000 – 0x6f32bfe3 QuickTimeH264.scalar ??? (???) <275FEF5D-B116-979D-9637-CDCEE2DDC820> /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
0x6f387000 – 0x6f390ff7 +com.cod3r.ac3movieimport 1.7.8 (1.7.8) <42661C74-305D-98D4-DF9E-FCB6F129E7A4> /Users/admin/Library/QuickTime/AC3MovieImport.component/Contents/MacOS/AC3MovieImport
0x6f395000 – 0x6f39cff7 com.apple.QuartzComposer.QTComponent 2.3 (49) /System/Library/QuickTime/QuartzComposer.component/Contents/MacOS/QuartzComposer
0x6f3a5000 – 0x6f3ddff7 +com.media100.VideoOutput.component 2.0.1 (2.0.1) <0C6EE43F-2349-CA4D-BFF4-AC5D458290E9> /Library/QuickTime/Media100 Video Output.component/Contents/MacOS/Media100 Video Output
0x6f500000 – 0x6f567fe7 com.apple.QuickTimeMPEG.component 7.6.6 (1756.15) <02371681-9219-5D3C-7AAD-68426F5D6B30> /System/Library/QuickTime/QuickTimeMPEG.component/Contents/MacOS/QuickTimeMPEG
0x6f57b000 – 0x6f6f3feb com.apple.QuickTimeStreaming.component 7.6.6 (1756.15) /System/Library/QuickTime/QuickTimeStreaming.component/Contents/MacOS/QuickTimeStreaming
0x6f83e000 – 0x6f840fff +com.Logitech.Control Center.Scroll Enhancer Loader 2.6.0 (2.6.0) /Library/InputManagers/LCC Scroll Enhancer Loader/LCC Scroll Enhancer Loader.bundle/Contents/MacOS/LCC Scroll Enhancer Loader
0x6f846000 – 0x6f848fff +com.Logitech.Control Center.Scroll Enhancer 2.6.0 (2.6.0) /Library/Application Support/Logitech/LCC Scroll Enhancer.bundle/Contents/MacOS/LCC Scroll Enhancer
0x70000000 – 0x700cbfff com.apple.audio.units.Components 1.6.4 (1.6.4) <67DA329D-A571-6066-953C-4BBFCBF87BD5> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x72600000 – 0x7271dfef com.diaquest.mxfexchange 0.9 (0.9) /System/Library/Frameworks/MXFexchange.framework/MXFexchange
0x8fe00000 – 0x8fe4162b dyld 132.1 (???) <1C06ECD9-A2D7-BB10-AF50-0F2B598A7DEC> /usr/lib/dyld
0x90003000 – 0x90047fe7 com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x90048000 – 0x90048ff7 liblangid.dylib ??? (???) /usr/lib/liblangid.dylib
0x90055000 – 0x9005fff7 com.apple.HelpData 2.0.5 (34.1.1) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x90060000 – 0x9006dfe7 libbz2.1.0.dylib 1.0.5 (compatibility 1.0.0) /usr/lib/libbz2.1.0.dylib
0x9006e000 – 0x9011bfe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) /usr/lib/libobjc.A.dylib
0x9011c000 – 0x901d5fe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
0x901d6000 – 0x901eafe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x901eb000 – 0x9020dfef com.apple.DirectoryService.Framework 3.6 (621.11) /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x90241000 – 0x90350fe7 com.apple.WebKit 6533.20 (6533.20.25) <0C572899-8558-34EE-ABB4-3D163FFF5192> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x90351000 – 0x9036fff7 com.apple.iChat.IMFoundation 5.0.5 (747) <4F6827AF-F713-A8F8-92E8-C9EC59D92416> /System/Library/Frameworks/IMCore.framework/Frameworks/IMFoundation.framework/Versions/A/IMFoundation
0x90370000 – 0x903d4ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x903d5000 – 0x903d6ff7 libScreenReader.dylib ??? (???) /usr/lib/libScreenReader.dylib
0x903d7000 – 0x90417ff3 com.apple.securityinterface 4.0.1 (40418) /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x90418000 – 0x9042aff7 com.apple.CoreMediaAuthoring 0.706 (706) <81D68084-D7BD-E52E-9B1C-C8EC0FCECE3C> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x9042b000 – 0x90488ff7 com.apple.framework.IOKit 2.0 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x907bd000 – 0x90900fef com.apple.QTKit 7.6.6 (1756.15) <32C49374-14BC-53E7-FBFF-E11B42A41F56> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x90906000 – 0x90910fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x90911000 – 0x90921ff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) /usr/lib/libsasl2.2.dylib
0x90922000 – 0x90925fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x90926000 – 0x90a1aff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <061ABF36-8BA9-79C1-6CE7-EC69A4998F51> /usr/lib/libiconv.2.dylib
0x90a1b000 – 0x90a3fff7 libJPEG.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x90b1d000 – 0x90b1dff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x90b6b000 – 0x90b6eff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x90b6f000 – 0x90bbcfeb com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <136BFA48-D456-B677-3B5D-40A6946C3A09> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x90bbd000 – 0x90c4ffe7 com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x90c50000 – 0x90c54ff7 libGFXShared.dylib ??? (???) <4F2199F0-320F-0B59-0380-D3131D644CBA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x90c55000 – 0x90c58ffb com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x90c59000 – 0x9106fff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x91070000 – 0x911a7ff7 com.apple.CoreAUC 6.04.05 (6.04.05) <4A2BEE1A-A74A-746B-EFA6-470CD3354252> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x911a8000 – 0x9122affb SecurityFoundation ??? (???) /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9122b000 – 0x9132cfe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) /usr/lib/libxml2.2.dylib
0x91332000 – 0x9143eff7 libGLProgrammability.dylib ??? (???) <2D172B4E-432F-D18E-EA99-3BD56DBE7649> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x9148d000 – 0x91786fef com.apple.QuickTime 7.6.6 (1756.15) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x91787000 – 0x917bfff7 com.apple.LDAPFramework 2.0 (120.1) <131ED804-DD88-D84F-13F8-D48E0012B96F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x917c0000 – 0x917fbfeb libFontRegistry.dylib ??? (???) <4FB144ED-8AF9-27CF-B315-DCE5575D5231> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x91804000 – 0x91810ff7 libkxld.dylib ??? (???) <585F0A91-EFB8-E066-BDFB-4AFF37A8C323> /usr/lib/system/libkxld.dylib
0x91811000 – 0x9188eff7 com.apple.iLifeMediaBrowser 2.5.4 (468.1.1) <93A47E48-2C1F-7BAE-AF9F-5F52130BE59F> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
0x9188f000 – 0x91899ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x9189a000 – 0x919c6ffb com.apple.MediaToolbox 0.484.20 (484.20) /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x919e0000 – 0x919eeff7 com.apple.opengl 1.6.12 (1.6.12) <81AEF74E-E33A-B021-9CDB-6199104105FF> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x919ef000 – 0x91a2cff7 com.apple.CoreMedia 0.484.20 (484.20) /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x91a2d000 – 0x91a34ff3 com.apple.print.framework.Print 6.1 (237.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x91a35000 – 0x91b13fef com.apple.QuickTimeMPEG4.component 7.6.6 (1756.15) /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
0x91b14000 – 0x91b8ffff com.apple.AppleVAFramework 4.10.23 (4.10.23) <57B7C626-F344-AB15-8556-00425FA765DE> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x91b90000 – 0x91d8eff3 com.apple.JavaScriptCore 6533.20 (6533.20.20) <011E271D-4CA4-FFB0-2EDD-13C31C239899> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x91e7c000 – 0x91ec0ff3 com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x91ec1000 – 0x91ec5ff7 libGIF.dylib ??? (???) <447BC6E8-4C56-3D5D-983B-6BEA0D26F319> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91ec6000 – 0x92080feb com.apple.ImageIO.framework 3.0.4 (3.0.4) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x92081000 – 0x920efff7 com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x920f0000 – 0x92414fef com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x92433000 – 0x9265eff3 com.apple.QuartzComposer 4.2 ({156.28}) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x9265f000 – 0x928d2fe7 com.apple.Foundation 6.6.6 (751.53) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x928d3000 – 0x9294cff7 com.apple.PDFKit 2.5.1 (2.5.1) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x9294d000 – 0x92962ff7 com.apple.iChat.InstantMessage 5.0.5 (747) <4E1D077E-3733-5565-ADB9-C9B2C3EC89BE> /System/Library/Frameworks/InstantMessage.framework/Versions/A/InstantMessage
0x92963000 – 0x92966ff7 libCoreVMClient.dylib ??? (???) <12EF6056-7AC7-6691-75A2-BD0675C56A35> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x92967000 – 0x92b6efeb com.apple.AddressBook.framework 5.0.4 (883) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x92b6f000 – 0x92b7fff7 com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x92b80000 – 0x92bd0ff7 com.apple.framework.familycontrols 2.0.2 (2020) /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x92bd1000 – 0x92c7fff3 com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92c80000 – 0x92c80ff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x92c81000 – 0x92cc3ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x92cc4000 – 0x92ceeff7 com.apple.shortcut 1.1 (1.1) /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x92d24000 – 0x92d44fe7 libresolv.9.dylib 41.0.0 (compatibility 1.0.0) /usr/lib/libresolv.9.dylib
0x92d45000 – 0x93065ff3 com.apple.CoreServices.CarbonCore 861.34 (861.34) <3DA9098F-B71B-4BDE-5DE5-4B76C49158EB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x93066000 – 0x9308dff7 com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x9308e000 – 0x931bcfe7 com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x931bd000 – 0x931feff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <95079B56-0B7B-F114-5C43-5220DBE0FBB1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x931ff000 – 0x9320aff7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <4560936D-7730-5DD2-BFD7-95270DDC210A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x9320b000 – 0x9324bff7 com.apple.ImageCaptureCore 1.0.4 (1.0.4) /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x93254000 – 0x9325afff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x9325b000 – 0x93269fe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
0x9326a000 – 0x9327effb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9327f000 – 0x93294fff com.apple.ImageCapture 6.0.2 (6.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x93295000 – 0x932b0ff7 libPng.dylib ??? (???) <65E824F7-523A-CC34-ABDD-2A3B12DE1CA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x932b1000 – 0x93367ffb libFontParser.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x93368000 – 0x935cdfeb com.apple.security 6.1.1 (37594) <251BA05D-6F3D-F687-77C2-15E52539F308> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x935ce000 – 0x935dfff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x935f9000 – 0x93a2eff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x93a54000 – 0x93b56fef com.apple.MeshKitIO 1.1 (49.2) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
0x93c54000 – 0x93c66ff7 com.apple.MultitouchSupport.framework 207.10 (207.10) /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x93c67000 – 0x93c86ff7 com.apple.CoreVideo 1.6.2 (45.6) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x93cf8000 – 0x93cf8ff7 com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x93cf9000 – 0x93d3fff7 libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x93d40000 – 0x93d42ff7 com.apple.securityhi 4.0 (36638) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93d43000 – 0x93e7fff7 com.apple.audio.toolbox.AudioToolbox 1.6.6 (1.6.6) <781018FB-474B-E09C-D419-5BFF80590A10> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x93e80000 – 0x93e86fe7 com.apple.CommerceCore 1.0 (9) <928FCA4F-1366-AE18-CF67-87C79F5DAC21> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x93e87000 – 0x93e87ff7 com.apple.Cocoa 6.6 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93e88000 – 0x93e91ff7 com.apple.DiskArbitration 2.3 (2.3) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x93e92000 – 0x93f2ffe3 com.apple.LaunchServices 362.2 (362.2) <77B97C8B-321D-46A2-1DB5-388E45DFBC9F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x93f44000 – 0x93f46ff7 libRadiance.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x93f47000 – 0x93f80ff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <90C5DE81-1BEF-D807-A898-0FC19BDD14EC> /usr/lib/libcups.2.dylib
0x93f84000 – 0x94106fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) /usr/lib/libicucore.A.dylib
0x94107000 – 0x94138ff7 libGLImage.dylib ??? (???) <1AF72191-087A-5D75-B3B9-3F537315F635> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x94172000 – 0x9424cffb com.apple.DesktopServices 1.5.10 (1.5.10) <2BA08DD4-35A2-A0FF-ADEA-B381F0CEEB81> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9427f000 – 0x942afff7 com.apple.MeshKit 1.1 (49.2) <5A74D1A4-4B97-FE39-4F4D-E0B80F0ADD87> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
0x942b0000 – 0x94301ff7 com.apple.HIServices 1.8.2 (???) <63B29FF5-7077-8317-E710-2D94ADF7B499> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x94302000 – 0x9439afe7 edu.mit.Kerberos 6.5.11 (6.5.11) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x94578000 – 0x94e58ff7 com.apple.AppKit 6.6.7 (1038.35) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x94e59000 – 0x94e8cff7 com.apple.AE 496.4 (496.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x94e8d000 – 0x94e98ff7 com.apple.CrashReporterSupport 10.6.7 (258) <71CC59D1-E197-7431-5973-2C079A749257> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x94f3a000 – 0x94f7afe7 com.apple.IMCore 5.0.5 (747) <625F3A2B-3E43-2BD2-99C0-58E1C1765F65> /System/Library/Frameworks/IMCore.framework/Versions/A/IMCore
0x94f7b000 – 0x95122ff7 libSystem.B.dylib 125.2.10 (compatibility 1.0.0) /usr/lib/libSystem.B.dylib
0x95123000 – 0x9515afe7 libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <7DCB5938-3140-E71A-92BD-8C242F30C8F5> /usr/lib/libssl.0.9.8.dylib
0x9515b000 – 0x95161ff7 libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <218EC7C4-0520-2D8C-62EE-AA82D35448FC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x95162000 – 0x95266fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) /usr/lib/libcrypto.0.9.8.dylib
0x95267000 – 0x95338fe3 ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <41417F73-42C5-FFC3-E7A1-EF94602CDCD6> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x95339000 – 0x953a3fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x95413000 – 0x95434fe7 com.apple.opencl 12.3.6 (12.3.6) /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x95435000 – 0x954ddffb com.apple.QD 3.36 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x95527000 – 0x9554fff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
0x95704000 – 0x95747ff7 libGLU.dylib ??? (???) <2C7B2727-26F6-F29D-9D15-33044E87359F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x95782000 – 0x95783ff7 com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x95794000 – 0x95794ff7 com.apple.Carbon 150 (152) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x9580a000 – 0x95817ff7 com.apple.NetFS 3.2.2 (3.2.2) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x95818000 – 0x95892fff com.apple.audio.CoreAudio 3.2.6 (3.2.6) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x95893000 – 0x95895ff7 com.apple.QuickTimeH264.component 7.6.6 (1756.15) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x95896000 – 0x958f0fe7 com.apple.CorePDF 1.3 (1.3) /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x958f1000 – 0x958f8ff7 com.apple.iChat.IMUtils 5.0.5 (747) <165000D5-219A-DFAE-68C6-25F6ED12A00B> /System/Library/Frameworks/IMCore.framework/Frameworks/IMUtils.framework/Versions/A/IMUtils
0x958f9000 – 0x9592ffff libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
0x95930000 – 0x9599fff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x959a0000 – 0x959f6ff7 com.apple.MeshKitRuntime 1.1 (49.2) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
0x959f7000 – 0x959f7ff7 com.apple.quartzframework 1.5 (1.5) <4EE8095D-5E47-1EB6-3A8A-6ECE3BEC8647> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x959f8000 – 0x95a3bff7 com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x95a3c000 – 0x95a9dfe7 com.apple.CoreText 3.151.8 (???) <6F5D6C49-4693-B9B7-6612-832E8F155747> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x95a9e000 – 0x95b5afff com.apple.ColorSync 4.6.6 (4.6.6) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x95b5b000 – 0x95b5cff7 com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x95b5d000 – 0x95bd4ff3 com.apple.backup.framework 1.2.2 (1.2.2) /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x95bd5000 – 0x95c12ff7 com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x95c13000 – 0x95c51ff7 com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x95c74000 – 0x95c75ff7 com.apple.audio.units.AudioUnit 1.6.6 (1.6.6) <253E9552-5CEA-0D5A-1EDA-3B8F669B79EA> /System
