Activity Forums Apple Final Cut Pro Legacy importing from Itunes
  • importing from Itunes
    Posted by Dave Colonna on August 26, 2005 at 10:18 pm
    I just got a number of cds of soiund effects. they are aac sound files and fcp or imovie will not let me import. I’ve tried everythign i know and i cant really figure it out. any help out there?
    thanks
    Sean Lander replied 21 years ago 2 Members · 1 Reply
  • Sean Lander
    August 26, 2005 at 11:26 pm
    You will need to first convert the files to .aif format. Set it as the default format in your iTunes preferences.
    Then select all the tracks you want in iTunes. Go to the advanced menu and select “Convert Selection to AIFF” but don’t let go yet!!!
    Now hold down the option key. Now let go and choose the destination for the files. Once they are somewhere on your hard drive you can now import them into Final Cut Pro using the import function.
