Activity › Forums › Avid Media Composer › Importing from GFPacks
  • Importing from GFPacks
    Posted by Ray Hageman on August 20, 2010 at 4:23 pm
    Not much of a techie here, so please bear with me. My problem is transcoding/importing video to an AVID Nitris DX from a GFPack shot on an Ikegami HDS-V10. About 60 percent of the video is transcoded, the other 40 percent is corrupted. I get this prompt when I try to play one of the bad clips:
    SWDecodeCvtr:: ExecuteRequest()
    CONSISTENCY CHECKFAILURE !?! : []
    I’m going to upgrade to 5.0.3–will that solve this issue?
    Thanks in advance!
    Ray
    Bouke Vahl replied 16 years, 1 month ago 2 Members · 1 Reply
  • Bouke Vahl
    August 21, 2010 at 7:54 am
    Not sure if the upgrade will fix it.
    I had trouble with the ‘old’ routine, using the third party software (forgot the name).
    However, i do know that the Ikegami’s have trouble themselves, creating corrupt clips in the camera.
    Ask the shooter. The cam should have told him if things went wrong.
    (i have a client using one, in the beginning 1 or 2 clips per pack were rotten.)
    I strongly suggest that the cam gets an update.
    On a side note, are you working in Pal or NTSC?
    I’ve made a small util that creates viewing proxies with TC from the packs. Works swell in Pal, but haven’t had a chance to test it in NTSC.
    If you’re lucky, perhaps a transcode to another codec using this thing could salvage a bit more. (40% is major….)
    If you could share a few testclips, that would be great.
    (contact me direct if you want.)
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
