Activity Forums Apple Final Cut Pro Legacy importing from dvd, vhs
  • importing from dvd, vhs
    Posted by Christopher Ballou on June 7, 2005 at 3:45 pm
    Hello everyone,
    I’m working on my first project and I’m trying to capture stock corporate footage on dvd and vhs by playing it and using the a/v output through a advc-100 and then a firewire to my G4.
    Ok, now on with the probem.
    I see the images in the capture screen preview and when I try to “capture now” it stalls for a 1-2 seconds and says:
    “Capture now has reached the end of the tape. All existing footage between the point where you started the capture and the end of the tape was captured sucessfully.”
    I cant get a frame of footage…
    Matthew Brunn replied 21 years, 2 months ago 3 Members · 6 Replies
  • Matthew Brunn
    June 7, 2005 at 3:52 pm
    Since the footage you are trying to capture has no time code, Do you have the deck control set to ” non-controlable” Then are you capturing to another hard drive? Don’t capture to your system drive if at all possible. Thirdly, we would need more info about your system, Mac type, ram, software versions and such. This will help us better advise you.
    Hope this helps-
    Matthew
    Dual 500 G4
    OSX 10.3.5
    Ram 1.38
    FCP 4.5/AE 6.5/DVDSP3
  • Christopher Ballou
    June 7, 2005 at 5:03 pm
    I was attempting to use the a/v outs from a dvd player into a advc-100 dv converter into by g4 (specs below)
    Christopher Ballou
    Dual 1 Ghz G4, 1.5 GB SDRAM, OS 10.3.9, FCP HD
  • Matthew Brunn
    June 7, 2005 at 5:19 pm
    Have you tried digitizing in iMovie? If it works then it should be a software setup of FCP being the issue. Do you use the easy setups in FCP? Have you limited your length of capture? Limit it to 5 minutes, and see if that helps. It sounds more like FCP is interpreting the DV converter’s signal wrong. Do you have a DV camera or deck to test with?
    Hope this helps-
    Matthew
    Dual 500 G4
    OSX 10.3.5
    Ram 1.38
    June 7, 2005 at 6:08 pm
    iMovie worked, I imported and put the quicktime in FCP.
    Do you know how I can switch the scratch disk in imovie?
    The conflict must be with FCP HD, thanks for all the help
    Christopher Ballou
  • Jeremy Lee
    June 7, 2005 at 8:06 pm
    the easiest way to go about fixing this problem is to close the log and capture window, reopen it and press play. that error appears just because the play button is not selected.
    good luck with your first project.
    peace and love
    jeremy
  • Matthew Brunn
    June 8, 2005 at 1:16 am
    What ever hard disk you save your iMovie project to becomes the scratch disk. As for FCP not digitizing, it’s not a hardware issue. I would trash prefs and try (I’m sure you have already). Hard drive journaling could be an issue, do a search on the FCP post. After that FCP could have just lost it’s mind. If someone else has any other ideas or options I’m running out quick without being at the machine.
    Hope this helps-
    Matthew
    Dual 500 G4
    OSX 10.3.5
    Ram 1.38
