Importing from copied P2 material
I hope someone can help here. I have a drive with all the correct folder structures as copied by the cameraman – 90% of the clips have already imported correctly into the FCP 6.04 I am using. I am having real issues with any clips that are spanned – none of them seem to come through.
I have followed all of the advice given here about turning off the Advanced Pulldown and Duplicate frames etc. etc. etc., I have copied one group of clips to a new folder structure – keeping the structure the same, attempted to import just those files and as a last resort I have even gone through and renamed all of the relevant clips. All to no avail – nothing will import these files.
I was advised to just import the MXF files direct with the help of the Calibrated MXF import tool – and the files did appear to import – BUT anything over 30″ has been limited to just that a really useful interview length of 30″!
So my questions are:
1: What is the codec I need to put onto the Mac (10.4.11) that will allow me to recode the MXF files to Prores 422 outside the FCP so I can then import them into my FCP?
2: Will that codec work with spanned clips?
3: Why does the calibrated mxf import tool limit clips to 30″ and not work with spanned clips?
4: Why has no one dealt with these problems yet?
5: Who came up with such a laborious and waste of time import workflow in the first place?
If you can answer questions 1 – 3 I would be more than pleased, 4 & 5 are simple frustration at the wasted time trying to get round these problems.
Peter
