Activity › Forums › Adobe Premiere Pro › importing from After Effects
  • importing from After Effects
    Posted by Michael Duff on May 15, 2005 at 1:36 am
    I’ve just installed Premiere 1.5 and am using it for the first time. I am a long time AE user. I rendered out a 1 minute clip from AE as a quicktime animation codec but Premiere doesn’t seem to import quicktime???? Is this for real? Surely I am missing something..maybe I have not installed a specific component or something.
    What process do you guys normally take in getting from AE to Premiere. Most of my AE clips will be about 1 minute long.
    Cheers
    Michael Duff replied 21 years, 4 months ago 3 Members · 5 Replies
  • Steven L. gotz
    May 15, 2005 at 2:16 am
    Premiere Pro likes Quicktime Animation codec just fine. Perhaps you need to install Quicktime 6 on your system>
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Michael Duff
    May 15, 2005 at 4:41 am
    I have quicktime 6.5.1 –
    Premiere just isn’t recognising the .mov files. When i expand the file types option in the import screen it doesn’t have an option for quicktimes….
  • Steven L. gotz
    May 15, 2005 at 5:03 am
    I have Quicktime Pro. Perhaps that is required before you can import Quicktime files. I have had it so long I really don’t know. However, my Premiere Pro 1.5.1 imports Quicktimes just fine.
    Steven
  • Aanarav Sareen
    May 15, 2005 at 4:55 pm
    Are you exporting the files as quick time references by any chance? Also, quicktime has a variety of settings. What are your export settings from AE?
  • Michael Duff
    May 16, 2005 at 10:50 pm
    well…..in the render queue I’ve got:
    Render settings – BEST SETTINGS – (my comp is PAL 768×576 square pixel)
    Output module: Format – quicktime movie
    Output info: Animation Compressor, spatial quality high 100%
    Embeddind OFF
    RGB
    Millions of colours
    premultiplied
    44.1K /16bit/stereo
    I’m sure my setting are correct. Except I didn’t interlace the footage because it is all made from graphics. I always use this setting at work and it is fine (Pinnacle Liquid Silver…..argh). Premiere just isn’t seeing any .mov files.
    If I can’t solve this what other options do I have for rendering out at “almost” lossless?
