Activity › Forums › Adobe Premiere Pro › Importing from After Effects
  • Importing from After Effects
    Posted by Renee Matthews on December 19, 2010 at 9:55 pm
    Hello!
    I’m trying to export an After Effects sequence/comp into Premiere Pro.
    Basically I made an adjustment layer with guassian blur, then 4 masks for blurring moving objects.
    When I import into Premiere Pro, instead of the blurs, etc – it’s a huge white layer over my footage.
    I tried rendering in after effects but that takes absolutely forever and I’m sure that Media Encoder or Premiere Pro will render it out faster…
    Any ideas? Thank you!
    Renee Matthews replied 15 years, 9 months ago 2 Members · 2 Replies
  • Todd Kopriva
    December 20, 2010 at 1:07 am
    > Any ideas?
    Yes. Render and export the composition out of After Effects.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Renee Matthews
    December 20, 2010 at 1:33 am
    Was just about to respond with an update – took me a while to figure out it needs to be in a composition, and that I have to manually go in and change the length of it to match the clip…
    Thank you 😀
