Activity Forums Avid Media Composer Importing from AE
  • Importing from AE
    Posted by Daniel D’avoine on August 17, 2009 at 7:54 am
    (i have also posted this in the AE section)
    Hi
    I am currently undertaking a project were i have to export some corrected footage, removing a television screen from a shot, back to avid from where it was captured. There is an issues that the interlacing is flicker whatever field i export it in, including, progressive scan. This issue occured previously in the project and was solved when i had exported a clip in lower field by importing it to avid in upper field any ideas?
    Captured to avid from digibeta mxf 1-1.
    exported from AE using uncompressed QT.
    Thanks Daniel
    Terence Curren replied 17 years, 1 month ago 3 Members · 2 Replies
  • Ryan Mcafee
    August 17, 2009 at 1:26 pm
    Try maybe exporting the AE footage as a Video for windows (.avi)
    Ryan McAfee
    Moon Community Access Television
    http://www.MCA-TV.com
  • Terence Curren
    August 18, 2009 at 4:47 am
    You are talking about how you export, but not how it is imported. Avid can import a clip upper, lower, or progressive. If you render out upper, and the editor imports lower, you will have a problem. Same thing if you do it the other way.
    Make sure you and the editor are using the exact same settings.
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
