Activity Forums Adobe Premiere Pro Importing from a Video
  • Importing from a Video
    Posted by Blondie4fun on October 27, 2005 at 2:24 pm
    Hi there,
    I am using Adobe Pre. Pro 1.5
    I don’t have any trouble importing video from my digital camcorder but I do have some trouble getting video on there to edit from the “OLD” camcorders that hold the BIG video tapes.
    How do I go about doing this?
    Hector Melendez replied 20 years, 11 months ago 3 Members · 3 Replies
  • John Baum
    October 27, 2005 at 3:24 pm
    You have to use your DV camera to convert the analog signal coming from your VCR to digital. Most all DV cameras can do this.
    You would play your old tapes on your VCR running either the composite or S-Video output into your DV camera. You will probably have to change some settings on your DV camera too, check your manual.
    Also, you won’t have control of the camera so you will have to manually start the VCR and hit “record” button in premieres capture window.
  • Blondie4fun
    October 27, 2005 at 3:29 pm
    Thanks so much, I will give this a try.
  • Hector Melendez
    October 27, 2005 at 3:31 pm
    Yes! this is the right way to go.
