Activity Forums Boris FX Particle Illusion Importing footage or image sequences.
  • Importing footage or image sequences.
    Posted by The Gare on October 19, 2005 at 5:32 pm
    OK, maybe I missed something, but I am totally new to PI and I cannot for the life of me find where to import the sequence. I can see where to import the background, but no option for a sequence. I am trying to duplicate Elvis’s awesome people disentigration effect, but cant get my sequence in.
    Thank for your help!
    The Gare replied 20 years, 11 months ago 3 Members · 5 Replies
  • Alan Lorence
    October 19, 2005 at 5:45 pm
    Have you checked the quickstart page?
    https://www.wondertouch.com/quickstart.asp
    Image, sequence, movie — pIllusion refers to them all as “background images”.
    Alan.
    wondertouch
  • The Gare
    October 19, 2005 at 6:28 pm
    Thanks for the link, however I did right click and it allows you to import a imge, but I could not select all the images in the sequence.
    I will try it again….
    Thanks for your help!
  • Alan Lorence
    October 19, 2005 at 6:32 pm
    Select a single image, and if pIllusion detects it as part of a sequence, it will tell you. It’s pretty particular about naming though — the sequence must be in the format filenamexxxxxx.etx Where “xxxxx” is a number sequence that uses leading zeros. For instance, test0001.tga and test0002.tga make a sequence.
    Alan.
    wondertouch
  • Elvis Deane
    October 19, 2005 at 6:34 pm
    When you select the first image in the sequence and import that, pI should ask if you want to import the entire sequence or just the selected image (as long as the images are named sequentially).
    Elvis Deane!
    The particleIllusion FAQ
    particleIllusion Resources and tutorial CD
    Astounding Adventures
  • The Gare
    October 19, 2005 at 8:47 pm
    OK, yea it did ask. I just did not go any further since I could only select 1 image. Now, how do I change my emitter to blank??? I downloaded the blank one, but cant find where to select it.
    Sorry if these are silly questions, but I am a new user of this app and it does not really help you much in certain areas. Looks VERY powerful though!
    Thanks again!
