Activity › Forums › Apple Final Cut Pro Legacy › Importing footage from VCR
  • Importing footage from VCR
    Posted by David Neuendorff on May 4, 2005 at 3:26 am
    New to using FCP. purchased ADVC110, loaded footage from VCR, seems to have loaded fine. Footage loads into FCP fine, but suddenly no audio. What am I doing wrong? I double clicked the file and it plays in quicktime so i know the audio is there? What is the newcomer doing wrong?
    thanks.
    Jerry Hofmann replied 21 years, 5 months ago 4 Members · 3 Replies
  • Shane Ross
    May 4, 2005 at 4:51 am
    Go to the FINAL CUT PRO HD menu and select AUDIO/VIDEO settings. make sure audio out is set to BUILT IN. If it is set to FIREWIRE DV, then the audio is being sent to your ADVC.
  • Matthew Brunn
    Could be a lot of things. When you drop it on a timeline, is there a red line on the top of the video track? Do you hear beeping when you try to play it? Then FCP needs to render the audio. If this is the case use one of the easy set-ups for FCP next time you digitize, make sure it is for the “non-controlable device”. Is it dead silent? If you can hear a very faint sound it maybe that your audio is 180 degrees out of phase. They end up cancelling each other out. Delete one track of audio and pan the remaining to the center. How about your audio levels? Do they read anything? Will it play in the veiwer and not in the time line? Timeline settings could be off. Get info on the file in Quicktime, what dose it say? DV NTSC 720X480 Video 29.97 fps 16 bit 48kHz audio? What is your audio output set to in FCP? Firewire port? Audio out? These are just some options, but without more info it could be anything.
    Hope this helps-
    Matthew
    Dual 500 G4
    OSX 10.3.5
    Ram 1.38
    FCP 4.5/AE 6.5/DVDSP3
  • Jerry Hofmann
    May 4, 2005 at 11:42 am
    To add to this post… you also can’t have the log and capture window open at the same time you are attempting to hear audio from a clip’s playback.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
