Activity Forums Apple Final Cut Pro Legacy Importing Footage DV/NTSC codec Hi Res into Final Cut Studio
  • Importing Footage DV/NTSC codec Hi Res into Final Cut Studio
    Posted by Annie Berman on March 14, 2007 at 1:14 pm
    A friend, computer wizard, figured out a way to capture dv footage hi res using a linux computer. (this enabled to captured 4 tapes at once). He used the DV/NTSC codec and we checked that all the settings matched final cut’s settings.
    The files play back in QT perfectly and QT identifies the codec as the same as FCStudios.
    However, when importing these files into FC Studio, 2 oddities occur:
    1. The files require rendering
    2. Media manager is unable to recompress file to low res
    any advice (besides capturing it all over using FC Studio)?
    Gary Adcock replied 19 years, 6 months ago 5 Members · 5 Replies
  • Walter Biscardi
    March 14, 2007 at 1:21 pm
    [Annie] “any advice (besides capturing it all over using FC Studio)?”
    Nope, capture in FCP. If you want to edit in FCP, capture all footage in FCP. Capture on any other platform and you’re asking for problems.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Paul Dickin
    March 14, 2007 at 1:34 pm
    Hi
    If only the audio needs rendering once the file is in a FCP timeline, then the movies have been captured as .dv DV-stream files, as used in iMovie.
    QT .mov files with the DV/NTSC codec are what they need converting into in order to work with FCP.
    I have quite happily uded FCP to edit DV footage captured in Premiere (older Mac versions), or with Sorenson Squeeze’s capture utility, but off-tape Timecode isn’t always useable once in FCP.
    If tape timecode is important its best, as Walter says, to stick with FCP for capture.
  • Peter Dewit
    March 14, 2007 at 1:39 pm
    If they are dv stream files I’ve had lots of trouble with them. they seem to have duplicate frame in FCP making the video look choppy.
  • Paul Dickin
    March 14, 2007 at 3:07 pm
    Hi
    That will happen if you’re standards-converting, using PAL DV movies in an NTSC DV sequence.
  • Gary Adcock
    March 14, 2007 at 3:19 pm
    [Annie] “The files play back in QT perfectly and QT identifies the codec as the same as FCStudios.”
    Windows and linux use a different field order for DV material…
    on the mac the NTSC dv fields are “lower” field first
    there is no such thing as hi rez DV files on the mac this may have caused your issue.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
