Activity › Forums › Apple Final Cut Pro Legacy › Importing Fonts into FCP/Livetype
  • Importing Fonts into FCP/Livetype
    Posted by Brian Mills on March 1, 2006 at 11:06 pm
    I have downloaded some fonts onto my Mac and put them in the “Fonts” folder inside the ‘Library” folder of MacintoshHD, yet they do not show up for use in FCP or Livetype. Is there another folder somewhere I should be putting them to be seen by these applications? Is there an import command I’m not seeing?
  • Bouncing Account needs new email address
    March 2, 2006 at 1:30 am
    You must have fonts that are TRUETYPE (Type 2) fonts for use in the native FCP text generators.
    ALL fonts for ALL your Mac programs can go into the Mac’s regular font folder.
    They will show up in FCP the next time you open the program.
    Drop any new fonts into the “Fonts” folder:
    User > Library > Fonts
    You can usually find TRUETYPE (Type 2) fonts available with many language characters on the web.
    NOTE:
    For more creative options you really should be using “Title 3D” (from Boris) for your titles and not the native FCP text generators.
    “Title 3D” CAN utilize both “Type 1” and “Type 2” fonts.
    “Title 3D” is included with FCP on your original FCP installer disks.
    You must CHOOSE to install “Title 3D” (and “Title Crawl”) when you have the install disk in the Mac.
