Activity Forums Adobe After Effects Importing Folder problems
  • Importing Folder problems
    Posted by Matt Carl on November 8, 2008 at 12:49 am
    Just got AE CS3 and am not able to import folders the same way I use to be able to in previous versions of AE (use to just select import and select desired folder and click the “Import Folder” button). Now when I do this it imports everything inside the current folder I am in (which does ultimatley include my desired folder but with a bunch of other stuff as well). The work around for me is to actually navigate inside my desired folder and then choose “Import Folder”. This is definatley a bug and am wondering if anyone else has encountered this (and if so do you know of a fix)??? Thanks
    Matt Carl replied 17 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
