Activity Forums Apple Final Cut Pro Legacy importing flash into Final Cut Pro…
  • importing flash into Final Cut Pro…
    Posted by Deformed on April 11, 2005 at 12:34 am
    Hi guys,
    I am desperate to play with layering flash animations over video / stills.
    I really need an application thatt I can imprt .swf files into directly.
    I tried exporting the flash as quicktime and importing into after effects, but the quality is horrible!
    Is it possible to import .swf files directly into Final Cut pro? If so, I will buy a copy!
    If not- does anyone have any other suggestions?
    many thanks-
    deformed
    Dario replied 21 years, 5 months ago 3 Members · 3 Replies
  • John Ladle
    April 11, 2005 at 3:54 am
    you can build good flash animations in combustion and bring those same layers with all of their quality into fcp or render a high quality right within combustion. but if you are looking to take flash animations made by another guy in flash, there will be some of the issues you have found.
  • Deformed
    April 11, 2005 at 10:20 am
    thanks for the reply…
    no, I will be making all the animations myself… What is combustion?
    many thanks-
  • Dario
    April 12, 2005 at 12:30 am
    Combustion is a video compositing app made by Discreet:
    https://www4.discreet.com/combustion/
    It is After Effects main competitor.
    You said the exported swf quality was horrible. How so? Pixelated, jerky, washed out…? Was the initial QT export out of Flash bad (try playing it in QT before going to AE) or just after you got it into/out of AE?
    I would suggest skipping Flash altogether for this. Go straight to Combustion or AE. Maybe even Motion would do what you want? Then, depending on what your expected output is to be (DVD, Film, Broadcast, Web) you might be able to get by with Final Cut Express. This limits you in a few ways (see here for a comparison between iMovie, FCE and FCP: https://www.apple.com/finalcut/) but ‘most’ are mitigated if you have AE or Combustion. Of course, going to film is a different story, you’ll need FCP for that.
    As for the animation stuff… Why Flash? For the vectors maybe? AFAIK, vectors aren’t of much value unless you’re intending to stay on the web. Plus, through Flash, I doubt you’ll be able to export an alpha channel, which is what you’d need to do the compositing you mentioned. Is it just the animation aspect?
    If so, take a look at Bauhaus Mirage:
    https://www.bauhaussoftware.com/home_LP.php
    This would allow the animations AND compositing in one app. In fact, if what you’re doing is short enough, say, less than 5 minutes, Mirage alone might do it without FCP or FCE.
