Activity Forums Apple Final Cut Pro Legacy Importing Flash into FCP
  • Importing Flash into FCP
    Posted by Stephen Lindsay on April 13, 2005 at 1:29 pm
    Hey everyone,
    I’m working on a commercial, and I need to import a Flash animation into FCP 4.1.
    It imports the SWF file fine, but it doesn’t keep the background of the file clear like I need it. Is there something special I need to do?
    Thank you,
    Stephen Lindsay
    David Hails replied 21 years, 4 months ago 3 Members · 2 Replies
  • Jeff Carpenter
    April 13, 2005 at 1:48 pm
    Go outsie Final Cut and try to open the file with the Quick Time player. Then export it from there as the type of video that your sequence is. That might work better. I’m not sure, but it’s the first thing I’d try.
  • David Hails
    April 16, 2005 at 8:18 am
    Hello,
    I had the same trouble a while ago, but I managed to sort it out.
    Instead of exporting a SWF from flash, export a 720 x 576 25fps quicktime movie (if working with PAL), or NTSC equivilant. Then create a new project in FCP, go to the sequence menu and then Settings, change it from DV to Animation.
    Bingo!
    Your sorted!
    Dave
