Activity Forums Apple Final Cut Pro Legacy Importing / Firestore / Frame Rate
  • Importing / Firestore / Frame Rate
    Posted by Chris Nguyen on January 21, 2011 at 7:45 am
    Hi there, I am using FCP 7.0.3. I have a HVX200 and a Firestore FS-100.
    I set my camera to shot 1080i/24p. The firestore is set to record the clips as QT. When I import the clips, FCP says that the “Vid Rate” is 29.97. Is that how it is supposed to be?
    When I import the same clips into Premiere CS5, they show up as 23.97.
    Any ideas? Thanks
    Jerry Hofmann replied 15 years, 7 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    January 23, 2011 at 2:27 pm
    Well…. for starters there’s not such thing as 1080i24p video… what did you REALLY shoot? There is 24 fps video spread over 29.97 however, and that’s probably what you’ve shot. You can remove the pulldown and make it a true 24 fps file, however it won’t look any different, because there really is only 24 individual frames in the current 29.97 fps file… there are redundant fields in the file and they can be removed, or not… look will be the same in the end…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Chris Nguyen
    January 24, 2011 at 5:46 am
    sorry, i meant 1080i/24f
    a problem that i am now encountering is that the clips are “choppy” in the fcp browser. the source file plays smoothly, and it plays smoothly premiere as well.
    fcp set up as dvcpro hd 1080. when i drag the clip to the timeline, fcp automatically adjusts the timeline to match the clip.
    mac pro intel quad core @ 2.67
    16 gig ram
    source files are captured on separate HD
    Christopher
    Digital Media Arts: Television Production
    California State University Dominguez Hills
  • Jerry Hofmann
    January 24, 2011 at 1:37 pm
    I don’t believe you have a problem… it could well be 24fps over 29.97. That would be pretty normal.
    Jerry
    Current DVD:
