Activity Forums VEGAS Pro Importing Final Cut Footage into Vega 9
  • Importing Final Cut Footage into Vega 9
    Posted by Rex Brown on February 20, 2010 at 8:42 pm
    I need some advice on the best way to work with some 720HD video that currently resides in Final Cut Pro on a Mac.
    I’m using Vegas 9 Pro and need to add some additional clips to the front and back of the existing footage. As of now there is no need to edit that existing footage.
    What format should I request they export? MP4? MOV?
    Are there any codecs to avoid?
    Thanks in advance.
    “The emptiest boxcar always makes the most noise.”
    Maduko World Headquarters
    Rex Brown replied 16 years, 6 months ago 2 Members · 4 Replies
  • Mike Kujbida
    February 20, 2010 at 10:42 pm
    Render from the Mac using either ProRes which Vegas can read as long as you have the newer QuickTime player installed or the free Avid DNxHD codec.
    This codec will need to be installed on both the Mac and the PC.
  • Rex Brown
    February 21, 2010 at 4:10 am
    See that’s what I was hoping to avoid. I have no idea what codecs they might have installed- and doubt they’d be inclined to install one on my behalf.
  • Mike Kujbida
    February 21, 2010 at 4:17 am
    AFAIK, FCP comes with ProRes these days so have them render it out in that format.
    Make sure you have a newer version of QuickTime player as it has the ProRes reader built into it.
  • Rex Brown
    February 21, 2010 at 4:30 am
    Aha!
    Now I get it. Thanks!
