Activity › Forums › Avid Media Composer › Importing Final Cut files into Avid Xpress Pro 5.1.5
  • Importing Final Cut files into Avid Xpress Pro 5.1.5
    Posted by Gael Firth on October 25, 2009 at 9:25 pm
    I need to import several Quicktime clips from a Final Cut project into my Avid Xpress Pro project that is running on a PC ( HP DX 7500 2.8 dual Intel processor, 4 gig ram).The media is on a mac formatted drive and I have access to a Mac Book Pro and can see the files no problem on that machine. How can I convert them to Avid files? Is there an Avid codec I need or a quick and easy way to get these files into my project? Thanks!
    Ed Cilley replied 16 years, 11 months ago 3 Members · 2 Replies
  • Michael Hancock
    October 25, 2009 at 9:46 pm
    You’ll need to import all the Quicktime files into your Avid, which will take awhile depending on the codec your files are in. If they’re Avid codecs you’ll have a fast import, but I assume they’re not.
    First, find out what codec these files are in. A lot of FCP Quicktime codecs are proprietary to FCP, so if you don’t have FCP installed (and if you have a PC, you won’t) you’ll need to convert them. If you do have to convert them, download the Avid codecs to the FCP system and convert them to the corresponding Avid codec (for example, DVCProHD converts to Avid DV100, DV50 to AvidDV and set it to DV50, etc…).
    Michael
    I’ll be working late.
  • Ed Cilley
    October 26, 2009 at 3:54 pm
    Let me tag onto Michael’s comments…
    I think the other question you are asking is how to mount a Mac formatted drive on your PC. Check out Mac Drive.
    https://www.mediafour.com/products/macdrive/
    This allows your PC to see the drive.
    Ed
    Avid and FCP Preditor
    _________________________________________________
    Anything worth doing at all, is worth doing well.
    – Philip Dormer Stanhope, Earl of Chesterfield
