Activity Forums Avid Media Composer Importing Final Cut captures to Avid Xpress DV
  • Importing Final Cut captures to Avid Xpress DV
    Posted by Ace Billet on June 20, 2005 at 5:57 pm
    Hi all
    I’ve got about 10 .mov files, each 20 min long, that were captured from a MiniDV cam on Final Cut.
    I want to edit them on Avid Xpress. What I did was import them to a bin
    (the application did some Fast Import of the files). Do I need to do any other conversion besides that?
    I just want to make sure I’m set to start working on the files, and not capture them again.
    am I in the safe ?
    cheers
    ace
    Intel Inside, the world’s most popular warning label.
    Todd Beabout replied 21 years, 3 months ago 2 Members · 1 Reply
  • Todd Beabout
    June 21, 2005 at 6:29 pm
    Make sure that you import them into Avid with the proper setting that you will be working with (i.e. DV, 1:1, whatever…). Once it is imported into Avid you are good to go.
    -Todd Beabout
    Vazda Studios
