Activity Forums Apple Final Cut Pro Legacy Importing files to edit in FCP
  • Importing files to edit in FCP
    Posted by John Scott on August 9, 2009 at 5:02 pm
    I am cutting a reel that will be used to make a dvd in DVDSP. I am getting confusing info from editing friends about what is the best way to get the the dvd media onto FCP and then into DVDSP. I am not sure on which is the best way to go for quality and stablility. my first attempt I imported my footage into Streamclip, exported as a h.264 Quictime( .I ran into many problems after cutting and exporting to quicktime file, my scenes were randomly out of sync, they were fine on the timeline. Plus I found that I have to go through compressor before using dvdsp when in the h.264 format. I would love for someone to just tell me the best way to import my footage through Streamclip and what would be a good file format to edit on and create a DVD so my video quality stays high! I see that a H.264 file is much smaller than a DV file but I have plenty of HS space. Thanks for any feed back…Creative Cow has been a godsend!
    John
    Charles Wren replied 16 years, 8 months ago 5 Members · 11 Replies
  • 11 Replies
  • John Fishback
    August 9, 2009 at 5:48 pm
    H.264 is not an edit codec. Here are my suggestions. Export from Steamclip to a high-quality codec like 8-bit Uncompressed or Pro Res (not HQ). That will preserve the quality from the DVD and allow you to add graphics without degradation (like you’d get using DV). After editing in FCP, export a QT (ref or self-contained). Use that in Compressor to make mv2 and ac3 files. Finally, bring the mv2 and ac3 files into DVD Studio Pro to make your dvd.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • John Scott
    August 10, 2009 at 11:20 pm
    Hey John thanks for geting back to me on my question..
    I’m still perplexed about all the chatter on which is the best codec to use when importing into FCP.
    Is it normal to have a 23gig file on a average 45min file. I have a few episodes of a tv show i directed that I want to put on my external hardrive and was suprised how big the file was when using the 8bit codec. a editor friend said I should use the H.264 to cut with but I was always having problems with sound sync when I exported out of the timeline to a quicktime self contained file…
    What about the DV codec or the QTDVPro50 codec do these doe the same thing??
    John
  • John Fishback
    August 11, 2009 at 3:22 pm
    Do NOT use H.264 as an edit codec. It’s a delivery codec. You’ll have all sorts of sync and render issues. DVCPro 50 would be fine for files coming from a DVD. You should have no loss of quality. With DVCPro 50 you’ll get around 2 1/2 minutes per GB which would translate to around 18GB per 45 min program.
    John
  • Walter Biscardi
    August 11, 2009 at 3:28 pm
    [John Scott] ” a editor friend said I should use the H.264 to cut “
    Never. H.264 is a delivery codec, never use it for editing. It was not designed for editing.
    DV50 will be cleaner in the finished product than DV.
    Keep in mind your original video is very heavily compressed so you want to re-compress it as little as possible. When I bring in stuff from a DVD we usually use 8bit Uncompressed or ProRes.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    Credits include multiple Emmy, Telly, Aurora and Peabody Awards.
    Owner, Biscardi Creative Media featuring HD Post
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Read my Blog!
    Twitter!
  • John Scott
    August 11, 2009 at 4:27 pm
    Thanks to both of you! I should have came here from the beginning of my editing project it would have saved me HOURS of time!! My Leige!!
    John Scott
    Director :
    nip/tuck
    Glee
  • Chrissy Chris
    September 6, 2009 at 2:41 pm
    Hi there guys!
    First: Love niptuck.
    Second: my new AVCHD camcorder files give me a headache.
    I’m trying to convert AVCHD (MTS) files into quicktime files to be able to edit them in FCP (because if FCP is on a mac without intel, it cannot read AVCHD a.k.a. MTS files).
    I use AVS video converter to read these files and convert them. Because I cannot choose from the formats/ codcs named above by you guys, my question is: Do you maybe have any advice which other format/ codec to use? Here are my options:
    If I choose to convert to Quicktime, I can choose either h264 (which as i read above and i experienced myself is not an edit codec) or mpeg4 or sorensen video.
    If I choose to convert to MPEG, I can either choose MPEG1 or 2
    and NTSC/PAL (for me as a european: PAL) or HD or creative zen vision M.
    Thanks in advance and kind regards,
    Chrissy
  • John Scott
    September 6, 2009 at 11:05 pm
    Have you tried downloading MPEG Streamclip ? I have found that this free utility software quite usefull and easy for doing any kind of file conversion. There is also one called Handbrake.
    JOhn
  • Chrissy Chris
    September 7, 2009 at 8:05 pm
    Thanks John!
    I did. So I saw that there were again a million different options in MPEG streamclip.
    So after converting my HD camcorder files with AVS from AVCHD (a.k.a. MTS) to Quicktime .MOV format, but still in H264 “subformat”/ codec, I converted the .MOV files with mpegstreamclip to (still interlaced) DV-PAL (european!) format, 720 px.
    FCP eats it. Though, now i have a loss of HD quality. Do I need to convert them to DVCPRO-PAL in order to keep the quality?
    You are soooo saving my butt!! Thanks so much!
  • John Fishback
    September 7, 2009 at 8:11 pm
    Instead of DV-PAL try ProRes. That should keep your program in HD.
    John
  • Chrissy Chris
    September 7, 2009 at 8:24 pm
    Thanks a lot other John!! :-)))
    Good luck you guys with editting and directing and thanks for the help!
