Activity Forums Adobe Premiere Pro Importing file
  • Importing file
    Posted by Belinda Edwards on January 7, 2008 at 5:59 am
    I have PP CS3. Is there a reason that it won’t let you imort Quicktime .mov files? Everytime I try to import a .mov file, I get a windows error, that states “do you want to report this error to Microsort, then shuts down the program. Any ideas?
    Mike Velte replied 18 years, 7 months ago 2 Members · 5 Replies
  • Mike Velte
    January 7, 2008 at 12:16 pm
    What is the Format of the Video AND Audio tracks? Open the video file in QT Player and choose Window>Show Movie Properties.
  • Belinda Edwards
    January 7, 2008 at 5:14 pm
    I don’t have QT Pro, so that choice is not available to me. If I click on “Movie Inspector”, this is what I get:
    Sorenson Video 3, 880×660, Millions+, Mpeg Layer 3, Mono, 44.100Khz, PNG, 880×660, Millions+
  • Mike Velte
    January 7, 2008 at 7:32 pm
    Confusing information!
    2 video codecs??? And then Sorenson does not support an alpha channel (Millions+). PNG does support that though.
    Really odd resolution.
    Premiere Pro often rejects Mpeg 3 audio.
    If QT Player can play it, your best solution might be to buy QT Pro to convert the clip to, like QT Animation and Linear PCM audio(48,000hz)
  • Belinda Edwards
    January 7, 2008 at 8:34 pm
    It seems to import fine to Sony Vegas Pro. I am just wanting to put some mov files together, and have been wanting to learn PP, and can’t figure out why one NLE will accept them, and another one won’t.
  • Mike Velte
    January 8, 2008 at 12:30 pm
    Premiere Pro will not import other formats as well. I use Premiere Elements to edit or convert those. Either edit in Vegas or use Vegas to convert the format.
