Activity Forums Adobe After Effects Importing File cause AE to crash
  • Importing File cause AE to crash
    Posted by Toddles on May 23, 2006 at 4:45 am
    Hi all,
    As soons as I go to import a file AE automatically crashes. This is only just started and I’ve never experienced it before. Any ideas would be much appreciated.
    Regards
    Tod
    Toddles replied 20 years, 4 months ago 3 Members · 4 Replies
  • Posix6
    May 23, 2006 at 4:03 pm
    happens to me too when i import image sequences of ~1000 files.
    however ae isn’t exactly “crashing”, i’d say. it’s not like you get an error message or anything. the whole process just disappears from one moment to the other. i find this a little amusing considering the minutes it can take to properly shut ae down when you’ve worked for quite a while.
    usually, the problem occurs to me the moment i want to rename the image sequence (ae7pro here). sometimes just moving the mouse inside the project window is enough though.
  • Toddles
    May 23, 2006 at 10:29 pm
    Ok, sorry, I should have explained this a little better.
    It happens as soon as i click on ‘Import File’. There is no warning message at all, AE just completely closes itself
  • Serge Hamad
    May 23, 2006 at 11:01 pm
    Hi Tod,
    Trash AE’s prefs file. If you have some custom settings they will be gone though.
    Salut.
    Serge
    “InvigoMany” available here:
    https://www.nyc-visual.com
  • Toddles
    May 23, 2006 at 11:10 pm
    Thanks Serge, I’ve just tried this but it is not helping.
    Cheers
    Tod
