Activity › Forums › Apple Final Cut Pro Legacy › Importing & Exporting Log and Capture Data
Posted by Razamataz on January 3, 2007 at 8:26 amIs there a way that I can export XML data for a batch capture list so that I can re-import it at a later date?
Chris Borjis replied 19 years, 8 months ago 3 Members · 4 Replies -
Shane Ross
January 3, 2007 at 8:30 amJust save the project file. Then you can open it and capture whenever you need.
Shane
FCP Preferences set to UNCONTROLLED ADVICE
Littlefrog Post
http://www.lfhd.net -
Razamataz
January 3, 2007 at 8:40 amI know I can do this but I need to be able to use xml data or something similar because i’m trying to write a third party app to assist in log and capturing. The idea is someone does a paper edit using this tool and in turn it generates the xml log sheet for importing into final cut.
Shane Ross
January 3, 2007 at 9:07 amThere is an Excel spreadsheet template available at http://www.larryjordan.biz that I have used on many an ocassion. Not XML, but a form that you can type into.
Shane
Littlefrog Post
Chris Borjis
January 3, 2007 at 5:23 pmShane can that be imported in fcp?
I can’t count how many times I’ve wanted a logging app that would work from a pc or mac just to do the laborious task of making capture logs, so I don’t have to waste time on the edit system doing it.
