Activity Forums Avid Media Composer Importing Edl
  • Importing Edl
    Posted by Tony Brecknock on September 6, 2007 at 7:31 pm
    I am doing a cut on an older editor and want to import an edl into Avid. I want to retain the comments and the reel numbers of the original batch grab on the older NLE. What edl format should I export from the old NLE and how do I import it into the Avid to retain all the original source information on the individual clips?
    Jon Zanone replied 19 years ago 2 Members · 3 Replies
  • Jon Zanone
    September 7, 2007 at 11:05 am
    What kind of ‘older NLE’ are you talking about?
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Tony Brecknock
    September 9, 2007 at 1:36 am
    It is a discreet edit. I am doing some SD offlining on it and want to bring it into Avid and keep the clip information with the edl.
  • Jon Zanone
    September 9, 2007 at 11:57 am
    I know if you register with Avid (you’ll need to provide your system ID) you can access the download area for Avid. I’m sure you can find a PC version there.
    Jon
