Activity › Forums › Maxon Cinema 4D › Importing DXF from Alias
  • Importing DXF from Alias
    Posted by Scott Gaskin on April 9, 2009 at 10:01 pm
    Can any one please help….A friend has designed some 3d models in his Alias program and exported them as DXF files so that I can animate them in Cinema 4D. They do open up in C4D except that some over the rounder shapes arn’t as slick as they look in the Alias program used to create the models, they are not as smooth as they should be. Almost a bit hexagonal. Can anyone advise?
    Cheers
    Scott
    Brian Jones replied 17 years, 5 months ago 2 Members · 3 Replies
  • Brian Jones
    April 9, 2009 at 10:06 pm
    add a Phong tag to your objects
  • Scott Gaskin
    April 9, 2009 at 10:22 pm
    Hi Brian,
    Thanks for the message. Can you explain how this is done in? Please forgive me as I’m very new to this 3d stuff and my technical knowledge is very limited!
    Many thanks
    Scott
  • Brian Jones
    April 10, 2009 at 12:03 am
    either
    – right-click on the imported DXF in the Object Manager (if you don’t know which part of the interface that is you’re going to have to check the Help) and choose Cinema 4D Tags/Phong from the contextual menu that pops up
    or
    – with your DXF selected in the Object Manager go to the Tag menu in the Object Manager and choose Cinema 4D Tags/Phong from there.
