Activity › Forums › Apple Final Cut Pro Legacy › Importing DVDs
Importing DVDs
Posted by Gabriela Enis on September 27, 2007 at 8:47 amHello,
This is my first question to the forum, I’m looking forward to many helpful and clear answers.
I would like to import films from dvds. Can you do that in FCP 5.1?
Many thanks,
Pepa
David Sikes replied 18 years, 11 months ago 6 Members · 6 Replies -
Richard Harrington
September 27, 2007 at 1:03 pmMac the Ripper
DVD x DV
Cinematize“just google it”
13
September 28, 2007 at 3:25 amGlad you joined the pasture her on the cow.
This question is extremely common here on the cow. In the future, please do a search before posting a question.
Gabriela Enis
September 28, 2007 at 6:44 amThank you very much for the answers.
Yesterday I used Mac the Ripper but I still cannot get any sound with pictures. Why is that?
I will try the other suggestions and then I’ll report back.In response to zrb123. Yes after sending my first post I realised I could search the topic and I found a lot of info. Unfortuately because I’m new in these matters I couldn’t follow the explanations clearly so I’m glad I’m getting some feed back myself.
All the best,
Pepa
Paul Crowe
September 29, 2007 at 7:07 amHi Pepa
Mac the ripperjust rips the files off the disc. It won’t transcode them to anything you’ll be able to edit with. Some one mentioned to check out http://www.squared5.com. I’d agree got here and MPEG streamclip use this to make turn the files into something you can edit with like DV. But there’s it’s a brilliant (and free) program with many options to choose from.
Just make sure you’ve got the mpeg2 download for quicktime other wise Mpeg streamclip won’t work properly.
Good luck.
Tankboy -
David Sikes
October 9, 2007 at 5:32 pmMac the Ripper is just a DVD EXTRACTER. It does no conversion.
I use Handbrake (https://handbrake.m0k.org/?article=download), but my boss uses MPEG Streamclip. They’re both free.
Both work very simply:
Select the Video_TS file in the DVD
Choose your settings (Handbrake has a ton of presets: from iPod to Quicktime to MPEG 2)
Click start and let it crank away!
