Activity › Forums › Apple Final Cut Pro Legacy › Importing DVD to Final Cut
Posted by Annu Lilja on October 27, 2008 at 4:00 pmHi!
How do I import material from a DVD to Final Cut so I can edit it?
Annu
Anthony Fennell replied 17 years, 6 months ago 8 Members · 10 Replies -
Simon Hustings
October 27, 2008 at 4:23 pmI agree with Holly, MpegStreamClip is definitely the way to go. Works very well.
David Roth weiss
October 27, 2008 at 4:23 pm[Holly Middleton] “I use a free download called mpeg streamclip.”
That’s the ticket. Holly’s got it right. Works well and it’s free too. You can’t beat that.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Holly Middleton
October 27, 2008 at 4:25 pmI use a free download called mpeg streamclip. It sees the info from the Video TS and Audio TS and allows you to output a variety of formats that are FCP friendly. You can also set in & outpoints so there’s no need to convert the entire disc.
Dan Sparks
October 27, 2008 at 4:40 pmOne quick look at the FAQ section would have answered this question. It is in section “A” item #!. It was very nice of some folks to jump in and offer help, but the OP could have done a bit of homework.
Dan Sparks
Tricom Video
Annu Lilja
October 27, 2008 at 4:53 pmThanks for everybody’s help. And sorry if I bothered anybody with an obvious question, I tried looking for an answer before posting the question, but I guess I’m not the best at surfing the net! : )
Have a lovely day, everyone! And thanks again for your help.
Annu
Annu Lilja
October 27, 2008 at 9:12 pmHi,
does any of you have a suggestion what format I should use if I want to cut the material ripped from the DVD on my Final Cut? I want import the material to my FCP in using the best possible quality. What would that be?
Annu
Dan Sparks
October 28, 2008 at 12:37 amAnnu,
You may want to start a new post as this is a somewhat different topic. People that respond will want to know what your sequence settings are, and how you intend to distribute the final video. Is it for broadcast, the web, DVD? Is the DVD footage being edited together with other footage? If so just match the capture codec to the rest of the footage.Good luck,
Dan Sparks
Tricom Video
Rafael Amador
October 28, 2008 at 2:26 amHi Annu,
When you export with MPGStreamclip, dont choose “Export to DV” or you will get a DV Stream: The format used by iMovie (no TC and always need to be rendered in FC).
If you want to extract the best quality from the DVD set at least DV 50 as the codec.
rafael -
Walter Biscardi
October 28, 2008 at 2:30 am[Annu Lilja] ” I tried looking for an answer before posting the question, but I guess I’m not the best at surfing the net! : ) “
There is a FAQ (Frequently Asked Questions) on this very forum. This is what Dan was referring to. This is the answer he was referring to.
https://forums.creativecow.net/faq/applefinalcutpro#40
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Anthony Fennell
March 6, 2009 at 7:40 pmThanks for the info you listed
Mpeg Stream Clip works great ! No more real time encoding and its good enough for Govt work LOL
